:: View topic - M75 "multi tasking"
M75 "multi tasking"
Reply to topic     Forum Index -> Non Czech Languages Here
hungeri
PostPosted: Wed Dec 06, 2006 12:29 pm    Post subject: M75 "multi tasking" Reply with quote
Am I so stupid, or the M75 isn't able to do anything else while using music player? Ok, it can recieve SMS, or a call, or some kind of alert (calender, alarm clock), but am I able to do anything else??? I can't see the clock, I can't read / compose an SMS or message, or browse the wap. Ok, the most important would be the watch, why am I not able to see the time? I have to stop playing, press red button long, see the time, start music player again, select the playlist, and everything begins from the start... Or am I wrong? Is there a solution to make the music player a background event? Like stopwatch? I dubt... This is a very silly thing in M75... :(
132978.34 SMM
PostPosted: Wed Dec 06, 2006 3:48 pm    Post subject: Reply with quote
you need patch ### or elf XTask Hand
hungeri
PostPosted: Wed Dec 06, 2006 8:32 pm    Post subject: Reply with quote
Does that patch enable the native menu from everywhere after typing # three times? I never could imagine, what should be this patch useful for, but now, I will try it out! :) thx!
P.S.: "elf XTask": I can't understand this, I've never faced this kind of patch, could You explain something about it?
P.S. II.: Do I need MP and/or libaries for that kind of operations? Unfortunately I can't use MP patches, only the 'old', 'normal' ones, I can't understand how MP exactly works. If You have time, or fancy, could You write me something about MP, too?
Thx Your help (in advance too :) )!
132978.34 SMM
PostPosted: Wed Dec 06, 2006 10:35 pm    Post subject: Reply with quote
XTask is task manager like in windows.. wink you must have got patches: Elfloader, SWI, API and Big Function Library...
but for you will be easier ###, i think..
hungeri
PostPosted: Fri Dec 08, 2006 12:25 am    Post subject: Reply with quote
many thanks pip@, ### works fine! I'm so happy now :)
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
