:: View topic - D4X TnG v3 Windows Vista Aero S65v58
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 34, 35, 36  Next
Reply to topic     Forum Index -> Tuning
Jak moc se líbí?
Určo si to dám do founu :)
44%
 44%  [ 56 ]
Chtěl bych, ale mám jiný telefon (nechce to někdo portnout?:o))
51%
 51%  [ 64 ]
Nelíbí, jiný vkus/styl.
4%
 4%  [ 5 ]
Total Votes : 125
Bond
14861.00 SMM
PostPosted: Sun Dec 03, 2006 1:02 pm    Post subject: Reply with quote
sem si ho ted chtel zkusit nahrat akorat nemuzu najit takovou drobnost jako je kabel
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sun Dec 03, 2006 1:05 pm    Post subject: Reply with quote
rekl byhc ze by stacilo kdyby sis naletoval konektor na prst a na palec u nohy zase USB pak kanbel nepotrebujes
ale tomaslanger psal ze mu nejde beta3 tak nevim jesli pujde tobe Think dvojka sla pry v poho...
-> Nokia Lumia 800
Bond
14861.00 SMM
PostPosted: Sun Dec 03, 2006 1:45 pm    Post subject: Reply with quote
hmm pokazdy se mi to sekne na tyhle chybe
Cant connect to Mobile with BootstrapLoader on Com 5
koukal sem i na navod o chybach ale nemuzu ji nijak opravit Crying or Very sad
tomaslanger
PostPosted: Sun Dec 03, 2006 2:38 pm    Post subject: Reply with quote
To je stara znama zprava... ;-) Teda pro mne... Very Happy Udelal sem to tak, jak sem psal anglicky pro toho polaka a jelo to... ;-) jenom mi nejde to zadavani PINu... Razz Sad
C35i -> M35i -> A60 -> CSL65 -> S65
suawek
PostPosted: Mon Dec 04, 2006 7:39 pm    Post subject: Reply with quote
At last I've put SKEY into my phone, but still I cannot upload Your software. WinSwup shows an information I've written somewhere above (Cant connect to Mobile with BootstrapLoader). What the hell is going on? Smile Is there any other way to upload this soft to my phone?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Mon Dec 04, 2006 7:53 pm    Post subject: Reply with quote
This isn´t problem with the file, but this is problem with connection or cable. What cable do you have(DCA 500/DCA 510/DCA 540)? Check the settings in Winswup(e.g. right COM port) and try to load the firmware in Service mode.(To get the phone to Service mode you can use Siemens X65 Formating Tools(EEpromForm)
pluto3
Phone: SiemensSK65
9404.40 SMM
PostPosted: Tue Dec 05, 2006 2:18 pm    Post subject: Reply with quote
všechno tam nahážu winswup mi napíše Error on waiting for Stat-Data a pri pinu se to vypne tému tam mám standart
Siemens S65 FW58 zcizen
Dále: A35, C25, C55, M55, M75
tomaslanger
PostPosted: Tue Dec 05, 2006 2:47 pm    Post subject: Reply with quote
JJ, presne jako u pluta... Sad tohle mi to dela taky... Sad
suawek
PostPosted: Tue Dec 05, 2006 4:21 pm    Post subject: Reply with quote
I've got an original cable (COM) and two service cables (I use one of them to send patches to my phone). I tried to run my phone in Service Mode and then send software to my cell but it didn't work (I tried to do it with all the three cables I own and [probably] with all options that are possible to set up in WinSwup). What else can I do?
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Wed Dec 06, 2006 5:01 pm    Post subject: Reply with quote
lol... mno tak to bude asi neco se swupem Mad divne ze me vsechno vali tak jak ma Think zkusim udelt novy a testnu ho hned u sebe...
-> Nokia Lumia 800
nerow
tuner
tuner
8011.36 SMM
PostPosted: Thu Dec 07, 2006 2:40 pm    Post subject: Reply with quote
No něco na tom bude...Ja jsem taky dělal swup a všem to dělalo PX po zadaní pinu.Přitom mě to normálně šlo Think
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sun Dec 10, 2006 7:43 pm    Post subject: Reply with quote
Díky mému litevskému kamarádovi NForce jsem konečně sehnal betu2 přidána na 1. stranu topicu...
-> Nokia Lumia 800
alkaba
10903.00 SMM
PostPosted: Sun Dec 10, 2006 9:33 pm    Post subject: Reply with quote
Něco jsem si pučil (lépe řečenu šlohl) a trochu vylepšil Laughing
Mainscreen při nabíjení. S75 Angel
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sun Dec 10, 2006 9:52 pm    Post subject: Reply with quote
loooool jen by me zajimalo jak si dostal ikonu nabijeni na libovolnou souradnici Think pokud vim tak to neslo na x65
-> Nokia Lumia 800
PostPosted: Sun Dec 10, 2006 9:55 pm    Post subject: Reply with quote
Vsak on pise ze S75 Smile
Reply to topic     Forum Index -> Tuning All times are GMT + 1 Hour
Page 12 of 36
