:: View topic - D4X TnG v3 Windows Vista Aero S65v58
Goto page Previous  1, 2, 3 ... 12, 13, 14 ... 34, 35, 36  Next
Reply to topic     Forum Index -> Tuning
Jak moc se líbí?
Určo si to dám do founu :)
44%
 44%  [ 56 ]
Chtěl bych, ale mám jiný telefon (nechce to někdo portnout?:o))
51%
 51%  [ 64 ]
Nelíbí, jiný vkus/styl.
4%
 4%  [ 5 ]
Total Votes : 125
tomaslanger
PostPosted: Sun Dec 10, 2006 10:06 pm    Post subject: Reply with quote
Vzdyt jo, si dela D4X legraci, ne? Razz
C35i -> M35i -> A60 -> CSL65 -> S65
Doxxik
4285.00 SMM
PostPosted: Mon Dec 11, 2006 9:16 pm    Post subject: Reply with quote
tak sem tu asi 3 týdny nebyl a čumím jako puk! Shocked Shocked
Applause Applause Applause
Doxxik
http://www.youtube.com/watch?v=ZapMq2cDyZM
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Mon Dec 11, 2006 9:30 pm    Post subject: Reply with quote
Do starších tuningů přidán S75v47 D4X TnG v2. ThX to alkaba
-> Nokia Lumia 800
suawek
PostPosted: Tue Dec 12, 2006 4:34 pm    Post subject: Reply with quote
At last software updating is done. I've had to repair my phone's IMEI (using PapuaUtils). Now I have a few questions to You:
1. Where can I find themes that are shown on the first page of this topic?
2. Is it possible (for me of course Wink ) to have polish letters in font installed in this soft?
Thanks a lot for any answer Smile
P.S. Something's wrong with beta3 version in my case. When I uploaded it to my phone it turned off every time I pushed a button.
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Wed Dec 13, 2006 4:28 pm    Post subject: Reply with quote
jak se prave zjistilo beta3 mozna nejde kvuli absenci slozky gps v misc (0:/Misc/gps) byl bych rad kdyby to nekdo testnul a dal vedet jak to dopadlo...
-> Nokia Lumia 800
Siemensmaniak
PostPosted: Fri Dec 15, 2006 4:22 pm    Post subject: Reply with quote
neviete preco ked si nainstalujem betu 3 a zapnem mobil tak ked stlacim akukolvek klavesu pipne a vypne sa?
(pred instalaciou FW som si dal subory do Mobilu takze vtom to nebude)
suawek
PostPosted: Fri Dec 15, 2006 11:43 pm    Post subject: Reply with quote
I have the same problem / Mam ten sam problem Smile
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sun Dec 17, 2006 9:39 pm    Post subject: Reply with quote
problém bety3 vyřešen Applause
1. nahrát soubory a vytvořit složku Misc/gps
2. nahrát betu3 FW
3. nahrát EEPROM http://d4x.orpheusweb.sk/S65v58_D4X_TnG_v3_WVA_beta3_EEPROM.exe
4. odblokovat
5. zkusit zapnout
6. pokud PX tak ještě jednou
tento postup použil dle mého návrhu Bonfire a teď už si užívá veselého užívání D4X TnG v3 WVA beta 3 Angel Applause
-> Nokia Lumia 800
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Sun Dec 17, 2006 9:59 pm    Post subject: Reply with quote
ujde
Koupím Siemens, který nemám.
Crazy-pl2
PostPosted: Sun Dec 17, 2006 10:33 pm    Post subject: Reply with quote
In first good post I say hello to all user this forum Idea
I have n1 pack for upgrade this best soft for S65 Wink
1. FlexMenu -> delete your old FlexMenu from config and past this FlexMenu ther.
2. MyStuff -> (Edit MyStuff.xml with WordPad)
3. Lil bit of new patch, and Accu Temp on MP
4. Look on my PCT, I edit like: 'blinker', 'ExtraInfo', and lil bit off all patch Wink
BTW. To edit the FlexMenu use this.
What everybody think about that?
Its my last edit TnG soft:
Sorry about my easy english Wink And good luck in patching your phone Very Happy
P.I.M.P.=>CrazySL65 oraz S65turbo
GangstaTeamNet ComeBackSo...
suawek
PostPosted: Sun Dec 17, 2006 10:55 pm    Post subject: Reply with quote
Hello, can You - D4X - rewrite your last post in english 'coz it's hard to understand what You have written :/
I don't know what:
Quote:
5. zkusit zapnout
mean :/
Tell me something about unlocking my mobile after uploading EEPROM to my phone.
Thanks a lot
Siemensmaniak
PostPosted: Mon Dec 18, 2006 8:11 am    Post subject: Reply with quote
teraz sa ani nezapne pipne a hned sa vypne... Crying or Very sad
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Mon Dec 18, 2006 3:34 pm    Post subject: Reply with quote
to by ti melo delat kdyz neodblokujes...
-> Nokia Lumia 800
alkaba
10903.00 SMM
PostPosted: Mon Dec 18, 2006 3:40 pm    Post subject: Reply with quote
Hi. It looks nice, but i dont like the main screen Smile
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Mon Dec 18, 2006 3:50 pm    Post subject: Reply with quote
2. nahrát betu3 FW
4. odblokovat
5. zkusit zapnout
1. copy files and create Misc/gps folder
2. apply beta3 FW
3. apply EEPROM
4. unlock
5. try to power on
6. if phone crashes, try power on one more time...
-> Nokia Lumia 800
Reply to topic     Forum Index -> Tuning All times are GMT + 1 Hour
Page 13 of 36
