lc3 kolemjdoucí
Posted: Tue Feb 20, 2007 4:31 pm Post subject: Mrtvy cx 70 |
zdravim. mam siemens cx70 a pokazil sa mi a neda sa zapnut ale potrebujem z neho dostat aspon telefonne cisla lebo nie vsetky boli ulozene na sim karte. mohol by mi prosim niekto poradit ako?ak sa to da... |
D4X (o(^^)o)
Posted: Tue Feb 20, 2007 4:33 pm Post subject: |
mas hotovou FF nebo si s telefonem vubec nic nedelal? _________________ -> Nokia Lumia 800 |
lc3 kolemjdoucí
Posted: Tue Feb 20, 2007 4:35 pm Post subject: |
zatial nic, chcel som skusit flasher ten na x65 ale neviem co tam mam robit a nechcem to pokazit...
a telefon je v zaruke len neviem ci mi ho nahodou v servise nevymazu, preto chcem dostat z neho tie data.... |
D4X (o(^^)o)
Posted: Tue Feb 20, 2007 4:37 pm Post subject: |
zkus prehrat FW pres WinSwup... zaskrtni oba skipy (pre-check a post-check) potom start a promackavej cervene tlacitko kratce nez se spoji... (ale bacha abys ho nezapnul..) _________________ -> Nokia Lumia 800 |
lc3 kolemjdoucí
Posted: Tue Feb 20, 2007 4:40 pm Post subject: |
zapnut s mi ho asi nepodari... nakolko je kaput... ale skusim to ak to pochopim... zatial vdaka idem na to |
D4X (o(^^)o)
Posted: Tue Feb 20, 2007 4:41 pm Post subject: |
nemusis ho zapinat... jen musis zmacknout cervene tlacitko aby se spojil  _________________ -> Nokia Lumia 800 |
lc3 kolemjdoucí
Posted: Tue Feb 20, 2007 4:44 pm Post subject: |
ved ja viem ale ked si pisal ze ho nesmiem zapnut tak som pisal ze to sa mi urcite ani omylom nepodari.. inac kde najdem ten program ten WinSwup? |
D4X (o(^^)o)
Posted: Tue Feb 20, 2007 4:46 pm Post subject: |
sekce firmware... stahni si nejnovejsi s ikonou W pro tvuj telefon... _________________ -> Nokia Lumia 800 |
lc3 kolemjdoucí
Posted: Tue Feb 20, 2007 4:57 pm Post subject: |
napisalo >>> Could not Ping Mobile
a este >>> Cant connect to Mobile with BootstrapLoader on Com 3
a este toto>>> Error on waiting for Ack EOT
vzdy ked to skusim tak daco ine vyhodi... |
SPIKEBOY čestný člen
