:: View topic - telefonica o2 SK - wap a internet pre S55
skaloprd
PostPosted: Sun Apr 01, 2007 8:34 pm    Post subject: telefonica o2 SK - wap a internet pre S55 Reply with quote
Prosil by som o radu, ako presne sa nastavuje wap a internet pre S55 - operator o2 Slovensko - tie nastavovacie spravy akosi nechcu fungovat. Dakujem
14311.82 SMM
PostPosted: Sun Apr 01, 2007 8:46 pm    Post subject: Reply with quote
Ak to nejde cez SMS, tak ručne podľa Arrow http://www.sk.o2.com/sk/podpora/nastavenie-sluzieb.html
coyotelada22
PostPosted: Sun Apr 01, 2007 8:48 pm    Post subject: Reply with quote
staci len zapnut GPRS a nastavit v
Prenose dat v datovych sluzbach v ktoromkolvek profile GPRS-Udaje na
APN: o2internet a ulozit potom v HTTP-profile len vybrat ten ci si nastavil
a ulozit potom by mala ist opera aj JIMM
> 1 GB MS DV RS MMC Apacer
> 16 GB Micro SD class 2
>JBenchmark1 27 638 bodov
skaloprd
PostPosted: Sun Apr 01, 2007 9:07 pm    Post subject: Reply with quote
no skusil som, ale vidim to takto: ten HTTP Profil funguje na javu aplikacie (jimm, opera) a gprs funguje na ten vstavany wap prehliadac?
14311.82 SMM
PostPosted: Sun Apr 01, 2007 9:11 pm    Post subject: Reply with quote
áno, je to tak.
