:: View topic - MP14 a Patche pre SL65fw53
Goto page Previous  1, 2, 3 ... , 9, 10, 11  Next
majjkyy
PostPosted: Wed May 09, 2007 6:59 am    Post subject: ADPCM All Freq Reply with quote
Mate uz nekdo odzkousen tento patch pro CSL65 fw53? ja ho v pohode aplikoval bez jakekoliv chybove hlasky a nejde to.Kdyz si udelam jakoukoliv wavku vic jak 16kHz tak mi to napise ze format nejde prehrat.A ostatni hodnoty davam 8 bit,mono.Jestli nekdo vi jak na to dejte vedet.Diky
C35-M35-M55-C65 překopla na CSL65_FW53-Elfpack 1.8++ a dál ???možná C75
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Wed May 09, 2007 7:31 pm    Post subject: Reply with quote
máš to pořád ve formá tu IMADPCM?
nevim ale jakym programem na to .... buď windows Arrow záznam zvuku a nebo audacity...
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Thu May 10, 2007 9:10 pm    Post subject: Re: ADPCM All Freq Reply with quote
SKus najprv vyskusat to testovacie wavko co je tu prilozene: Test wav. Ak ide to tak chyba je len niekde v tom subore co si robil ty... skus zmenit nejake parametre alebo to spravit v inom programe...
dancas2
PostPosted: Mon May 21, 2007 4:22 pm    Post subject: Reply with quote
Hello Sefinko...
I need your help
I've installed elfpack 2.01 previously and it worked properly...
But now, with my firmware, i undo some patches for the correctly installation of patch, but, when i install elfpack 2.01 my phone turns on, but, when i enter my pin, it turns off...
I don't like elfpack 2.2 because it loads in bad colors the png's....
Do you have any solution?...
Bye
Cieniu
Location: -Poland- .:Szczytno:. Telefon: EL71 v45 PL I Csl65 v53
PostPosted: Mon May 21, 2007 7:28 pm    Post subject: Reply with quote
install new software and install elfpack on clear SW
www.forum.siemensiak.pl
dancas2
PostPosted: Mon May 21, 2007 10:51 pm    Post subject: Reply with quote
I don't wanna' do that... But, no problem, i was trying and now elfpack 2.01 works properly...
Thank you...
Bye
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Tue May 22, 2007 6:38 pm    Post subject: Reply with quote
i think there exist 2 variants of elfpack:
- 8bit png support
- 16 bit png support
so search up wink
dancas2
PostPosted: Fri May 25, 2007 12:15 am    Post subject: Reply with quote
And, can you tell me where find it? I say it because i'm columbian, and i don't understand czech and russian.. the elfpack's version that i have is in siemens-club..
Thanks and bye
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Fri May 25, 2007 2:36 pm    Post subject: Reply with quote
Thanks and bye
Look Here, this is ElfPack v 2.01 with patches which is need for MP14
I don't use elfpack v2.2 because it isn't good for me on Sl65....
dancas2
PostPosted: Mon Jun 11, 2007 6:27 pm    Post subject: Reply with quote
Thank's...
Me too, i use elfpack 2.01 too...
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Fri Aug 03, 2007 8:18 am    Post subject: ElfPack v2.3 pre SL65v53 Reply with quote
- aplikovat bud len ElfLoader v2.3 alebo potom ElfLoader v2.3_cz_sk (obsahuje standardny elfloader v2.3 + implementovanu cestinu vdaka truhlikovi) ale nie obe sucastne!
- dalej aplikovat kniznice nove kniznice s nazvom swilib_310507 po odobrati starych wink
- zatial som ho este neskusal, ale v najblizsej dobe sa do toho pustim, najlepsie je urcite vsetko robit na prehraty fw 8) tak to pojde urco vsetko vsetko bez chyb... (Not tested!)
Zoznam potrebynch patchov a suborov:
Code:
ElfPack v2.3:
- swilib_310507
- ElfLoader v2.3 alebo Elfloader v2.3_cz_sk
- potrebne elfy (zlozka Data)
- vsetko potrebne sa nachadza na linku Downloads
Arrow Downloads
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Aug 08, 2007 7:18 am    Post subject: Reply with quote
Skusal uz niekto ten ElfPack v2.3? Ja som ho skusal ale nie na cistu fw aqle len odobratim stareho vsetko slo, akurat mi stale ne ploche preblikuje nejake prehliadne pozadie, a napr. mi nejde dobre zobrazovat patch BigDigitalClock, ked v nom nastavim trochu prehliadne farby tak stale ukazu ako nepriehladne. Cize prehladnost ako keby stale bola na maximum (64)... (Obrazky do toho patcha mam GPP)
P4priX
128.03 SMM
PostPosted: Wed Aug 08, 2007 8:48 am    Post subject: Reply with quote
Já na Elfpacku2.3 funguju normálně, akorát mám problém s tím, že mám odtraněny popisky softkey a na jejich místo posunuty hodiny a datum. Když však vysunu slider (a odblokuju klávesnici) tak mi ty hodiny zmizí a musím je něčím překrýt a pak se ukážou, třeba dát dvakrát red key, nebo vlézt do menu a zase zpátky na MS Eh?
Arrow
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Aug 08, 2007 8:57 am    Post subject: Reply with quote
No ale ty mas EL71 a ja som myslel o radu x65 presnejsie SL65 lebo tam byval problem s picture add-on, ktory kolidoval s elfpackom.
A inac na EL mi ide elfpack v 2.3 uplne v pohode nerobi mi ani to co si pisal, cize problem bude musiet byt niekde inde asi v nejakom patchi alebo elfe co pouzivas
P4priX
128.03 SMM
PostPosted: Wed Aug 08, 2007 9:00 am    Post subject: Reply with quote
jááj sorry, nějak jsem se překouk Embarassed
Page 10 of 11
