:: View topic - T9 file
T9 file
Goto page 1, 2  Next
Reply to topic     Forum Index -> Non Czech Languages Here
Damir
PostPosted: Mon Jun 11, 2007 1:32 pm    Post subject: T9 file Reply with quote
Hello,
I've installed the latest firmware (FW52) for my Siemens SL75. The problem is that is doesn't have any T9 file. Is it possible to install the dutch T9 on my mobile?
Damir
drp
Phone: m65,se w610
31463.96 SMM
PostPosted: Mon Jun 11, 2007 2:11 pm    Post subject: Reply with quote
yes(raknu vam ze moc anglicky neumim takze sem si to prelozil slovnikem a jestly to prelozilo spravne tak yas)
Damir
PostPosted: Mon Jun 11, 2007 4:41 pm    Post subject: Reply with quote
Where can i find a dutch T9 file? And can someone help me to install it?
dohaa32
PostPosted: Wed Jun 13, 2007 1:52 pm    Post subject: Reply with quote
As far as i know it is difficult in SL75, and s68
i have s68 , made a backup from another s68 with same version and put it on the other s68, but the t9 won´t work...
i think it is not like the x65
Vladimir Curcic
PostPosted: Thu Jun 14, 2007 1:27 am    Post subject: Reply with quote
9
Someone, somewhere, on some German forum wrote this for S75:
Set your menu language / T9 to English
Restart the phone.
Connect the phone to the PC and copy your T9 dictionaries to the phone's folder: \Data\System\T9\
Restart the phone
Activate new T9 dictionary
Restart the phone
Set your menu language / T9 language
See if it works (!?!)
S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75
dohaa32
PostPosted: Thu Jun 14, 2007 11:24 am    Post subject: Reply with quote
Vladimir Curcic wrote:
9
Restart the phone.
Restart the phone
Restart the phone
thnx for reply
did all that, but when choosing t9 am getting error, file not readble, if i remove same t9 from the working phone (with t9) and put again it works, but will not work on other phones:(
do u know how to export/import (t9) work?
flemo
3205.06 SMM
PostPosted: Thu Jun 14, 2007 11:50 am    Post subject: Reply with quote
Problem is, that you need to installed something like license for each t9 dictionary you want to use.
If you remove some ldb file, you can put it back any time and it will work, because license file remains in phone, but if you add ldb file, that was never before installed into phone, it will be unreadable.
It is discussed also here, you can find there package of t9 files and their license files:
http://www.siemensmania.cz/forum/viewtopic.php?p=340969
License files are installed through "Config" drive. Unfortunatelly, you need to have phone in "Factory mode" security status to be able to see and write on "Config" drive. You need SKEY.
dohaa32
PostPosted: Thu Jun 14, 2007 12:52 pm    Post subject: Reply with quote
thnx again for ur effort
can i read license file from a phone and put it 2 another one?
do u have licene file for danish?
what program i have 2 use so i can c `Config` drive?
Thnx Again
flemo
3205.06 SMM
PostPosted: Thu Jun 14, 2007 1:01 pm    Post subject: Reply with quote
License files cannot be copied from one phone to another. If you look into the file (T9.zip, that I have given link in other topic), there are files with extenion drc. These files are used by phone to create license files, when copied into Config/drm/pre_inst. I haven't any other languages, only these you can find in zip.
If you can read german, here is some info how to get phone into Factory mode.
http://forum.modopo.com/showpost.php?p=118668&postcount=1
dohaa32
PostPosted: Thu Jun 14, 2007 1:16 pm    Post subject: Reply with quote
yes understand now thnx..
by the way i think i can go around this problem if i flash.xfs file (it has the language and t9 i need), the problem is that':
I am trying to update .xfs to my sl75, but getting this error:
Function not supported until now in Mobile.
am using winsup 4.18
Model: SIEMENS SL75 39 lg2
xfs file: SL75_2_no-Retail-NORDIC_39_0358.xfs
can u please help
flemo
3205.06 SMM
PostPosted: Thu Jun 14, 2007 1:20 pm    Post subject: Reply with quote
Sorry, I have no experience with xfs files. Maybe you need "Factory mode" also for this operation
dohaa32
PostPosted: Mon Jun 18, 2007 11:13 am    Post subject: Reply with quote
THNX FOR UR HELP, BUT NEED MORE (AM GREEDY FOR INFO)Smile
i used martech for reeding the full flash from s68..generate the keys esn boot and skey..
i need t know which program 2 use t acces the Config/drm/pre_inst., because still not working for the other s68, even after writing full flash and changing the imei to original again... sorry i can´t german.
dohaa32
PostPosted: Thu Jun 21, 2007 3:19 pm    Post subject: Reply with quote
I could manage everything now , but the only think i need is the t9da.drc file...
i could download one ffsinit file with t9da.drc inside, but the problem is that I can unpack/extract the files from this file...tried many exe unpackers but no luck...Any Idea...?
appreciate ur help.
Vladimir Curcic
PostPosted: Fri Jun 22, 2007 1:18 am    Post subject: Reply with quote
appreciate ur help.
Example, you have the FFSInit file "FFSInit_SL75_2_ua-retail_39_0358.exe"
1. Copy your FFSInit file to C:\TEMP
2. Start any Winswup firmware update file and leave it running
3. Start / Run:
C:\Temp\FFSInit_SL75_2_ua-retail_39_0358.exe /UNZIP
(there is a blank space before "/UNZIP"!)
And you will find a new folder: C:\Temp\FFSTool with all the contents of your FFSInit file unpacked.
Smile
dohaa32
PostPosted: Fri Jun 22, 2007 9:57 am    Post subject: Reply with quote
appreciate ur help.
3. Start / Run:
Smile
thanks for reply and info
i did all that but no unpacked files at the temp folder( i created and put the ffsinit file).
just the init file pops up when running the command:
c:\ffsinit.exe\ UNZIP
P.S I just ran any winsup without connecting any phone 2 it.
any idea what am doing wrong?
shall i have UNZIP program in same temp folder or what?
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
