:: View topic - divny patch
divny patch
usakc
I love SX1
27417.98 SMM
PostPosted: Thu Jun 28, 2007 1:20 pm    Post subject: divny patch Reply with quote
nevite na co je tento patch?
Code:
; *** DebugEmulator 1.0 ***
; *** Debug Emulator ***
; Author: fca00000 , fca00000-at-yahoo-dot-es
; Date: 2006.08.24 v1.0
; Firmware: Emulator Siemens-SX1
; File: C:\Symbian\6.1\Siemens\SX1\bin\epoc32\release\wins\udeb\ekern.dll
; This patch is useless for almost everyone.
; When you install the SDK it includes the SX1 emulator. Some debugging info is sent to
; EPOCWIND.OUT
; And some more information is sent to the Debugger. You can get much more tracing with this patch.
; As a debug monitor you can use DebugView from www.sysinternals.com
; For the curious people: I changed Ekern.dll in method
; 5B01285A mov eax, dword_5B0408CC
; into
; 5B01285A mov eax, FFFFFFFF
replace:A1CC08045B:B8FFFFFFFF
; As far as I know, nothing is broken. But I decline all responsability, of course.
; Anyway, here it is. Enjoy
; En el SDK se incluye un emulador del SX1
; Este parche permite mostrar mas informacion en el debugger.
; Hasta donde yo he comprobado, no he roto nada. De todos modos yo no me hago responsable.
; end of DebugEmulator
Gwin
0.84 SMM
PostPosted: Thu Jun 28, 2007 1:38 pm    Post subject: Reply with quote
Podle popisu ti to bude do SDK posílat podrobnější informace při debugování. Nezkoušel jsem.
Gwin
0.84 SMM
PostPosted: Thu Jun 28, 2007 3:14 pm    Post subject: Reply with quote
Když už jsme u patchů, zkoušel někdo patch 115, resp. 116 z oslíku? Jedná se o zvětšení disku C na úkor disku A. Jde mně hlavně o velikost 0. (replace:E20E17A0E3:E20010A0E3)
Zkoušel někdo?
usakc
I love SX1
27417.98 SMM
PostPosted: Thu Jun 28, 2007 4:06 pm    Post subject: Reply with quote
no js jeste ne ale to muzu mit ten patch na 11mb c + tento kdyztak skusim
Unnamed
PostPosted: Thu Jun 28, 2007 4:46 pm    Post subject: Reply with quote
kdyz uz jsme u patchu, tak bych se chtel zeptat, kde sezenu patch, ktery mi nastavi polozku Uzamknout telefon na Restart a zaroven tuto polozku prejmenuje?
byl: Siemens A36, M35i, MC60, SX1; je SE K750i@W800
Klikni prosim. Smile
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
usakc
I love SX1
27417.98 SMM
PostPosted: Thu Jun 28, 2007 4:59 pm    Post subject: Reply with quote
aplikuj si mio multi patch tam je vsechno i toto
oOJaNcOo
PostPosted: Thu Jun 28, 2007 5:01 pm    Post subject: Reply with quote
ja mam patch od Mia a mam to tam aj restart aj uzamknut tel.
Gwin
0.84 SMM
PostPosted: Thu Jun 28, 2007 5:34 pm    Post subject: Reply with quote
Budeš si to muset upravit, něco je myslím přesně naopak než popisuje popis.
Code:
; *** Disable Menu Dangerous 1.0 ***
; *** Zakazanie nebezpecnych menu ***
; Date: 2006.01.16
; Firmware: Siemens-SX1 Possibly all versions. Tested on Iberia15.2 and O2-14
; Omap: Core-Img (Z1)
; In the main menu, there are 2 dangerous options: SwitchOff and LockPhone.
; V menu su dve nebezpecne polozky : Vypnut telefon a Zamknut telefon.
; This patch modifies both and redirects to LockKeypad.
; Tento patch modifikuje obe a presmeruvava ich na Zamknutie klavesnice.
; The phone can still be switched off by long-pressing the red key.
; Telefon stale moze byt vypnuty dhlym stlacenim cerveneho sluchatka.
; You can apply the first part (SwitchOff) or the second (LockPhone), or both.
; Mozete aplikovat iba prvu cast (Vypnutie tel.) alebo druhu (Zamknutie tel.) alebo obe.
; First part: this changes the string SwitchOff
; Prva cast: meni nazov  Vypnutia
replace:05C0E05F:06C0E05F
; this redirects SwitchOff
; toto presmeruvava
;replace:281C0021642200F052F8:1AE0
; Second part: this changes the string LockPhone
; Druha cast: meni nazov Zamknutia tel.
;replace:04C0E05F:06C0E05F
; this redirects LockPhone
; toto presmeruvava
replace:281CD830006804F017FA19E0:0FE0
; Patch moze byt nebezpecny. Autor sa zrieka zodpovednosti za skody sposobene patchom.
usakc
I love SX1
27417.98 SMM
PostPosted: Thu Jun 28, 2007 5:35 pm    Post subject: Reply with quote
ja tam zamknout tel. nemama a mam take patch od mia
oOJaNcOo
PostPosted: Thu Jun 28, 2007 9:56 pm    Post subject: Reply with quote
prepac je tam len uzamknut tlacidla. viem ze predtym som tam mal uzamknut tel. sorry. Smile
