:: View topic - urgent...: EL71 FF problem
Reply to topic     Forum Index -> Non Czech Languages Here
adigehalil
PostPosted: Sat Aug 04, 2007 6:27 pm    Post subject: urgent...: EL71 FF problem Reply with quote
a friend wrote my fubu to his el71. now he can't power on it. after pressing the power button there is only a bip. he doesn't have bootcore and eeprom backups or fubu. what can we do to repair it...?
View user's profile Send private message Yahoo Messenger MSN Messenger
Orpheus
14900.34 SMM
PostPosted: Sat Aug 04, 2007 10:27 pm    Post subject: Reply with quote
You need to unlock the phone.. then youll get it to work
adigehalil
PostPosted: Sun Aug 05, 2007 6:50 pm    Post subject: Reply with quote
how to unlock it...?
i searched in gsmhosting.
Quote:
Use the Attached File (EL71 v9) open with hexeditor and enter ur Hash and IMEI
Save the New bcore and Flash with Vklay
Set VDown is in Adress 0x03E020
i found this and he applied. after that he lost the connection with v-klay and papuautils...
Orpheus
14900.34 SMM
PostPosted: Sun Aug 05, 2007 9:03 pm    Post subject: Reply with quote
wtf? you edited something in hex and burned to bcore? The phone is probably dead..
All you needed to do is to open the newest x65, x75 Papua Utils 0.9.1 EN and in the "Various" section of the program click on the "5008 Unlock" button.
Unlocking the phone means, you burn your IMEI to EEPROM so its the same as in BOOTCORE. If they are the same, the phone turns on, if not, it beeps.
adigehalil
PostPosted: Sun Aug 05, 2007 9:11 pm    Post subject: Reply with quote
but he had written the fubu including bootcore...
Orpheus
14900.34 SMM
PostPosted: Mon Aug 06, 2007 9:03 am    Post subject: Reply with quote
He wrote the bootcore also? How is that possible? V_klay is default set not to write the bootcore. Well.. the phone is dead, you could try to make a testpoint if some exists
P4priX
128.03 SMM
PostPosted: Mon Aug 06, 2007 9:16 am    Post subject: Reply with quote
Yea, testpoint exists... I did make one wink
adigehalil
PostPosted: Tue Aug 07, 2007 4:51 pm    Post subject: Reply with quote
thanks...
he gave it to service...
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
