:: View topic - CX75 a minimalizace javy ,.,.jde to ??????
Goto page 1, 2  Next
PostPosted: Tue Sep 25, 2007 5:09 pm    Post subject: CX75 a minimalizace javy ,.,.jde to ?????? Reply with quote
CX75 a minimalizace javy ,.,.jde to ?????? .,,.
Prosim o radu
mam CX75 zavedeny S-KEY atd. a FW13
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Tue Sep 25, 2007 5:18 pm    Post subject: Reply with quote
ano pokud aplikujes elfloader a budes pouzivat elf Xtask
-> Nokia Lumia 800
PostPosted: Tue Sep 25, 2007 5:49 pm    Post subject: hmmm Reply with quote
uz mam v mobilu nekoli patchu ,.,. jen o elfech nejak nemam prehlad , netusim az tak co to je a na co to je a jak to pracuje a co stym ,,. jak do mobilu a tak ,. a ci si nemam dadej predtym dat FW25
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Tue Sep 25, 2007 7:23 pm    Post subject: Reply with quote
nebo jak si psal na SZ, muzes si aplkovat patch na servisni menu, potom na vstup do native menu pres ### a na mainscreeen natukat #### - LOGAL - enable ###
-> Nokia Lumia 800
PostPosted: Tue Sep 25, 2007 8:16 pm    Post subject: Reply with quote
mainscreen je co presne trosku v toim mam teraz gulaš a kdyz natuikam tech #### ,. tak se mi zobrazi ???? nekde ? neco kde je aj ten LOGAL ??? ( bo nic se nedela kdyz to natukam ),.bo vtomhle jsem lama bo nevim kde je to servisni menu ,.,. nebo jak sa aktivuje ,. nebo jak k tomu LOGAL se dostat nebo jak a kde to napsat ,.,.
DarkLegion
1453.28 SMM
PostPosted: Tue Sep 25, 2007 10:12 pm    Post subject: Reply with quote
ja mam tiez cx75 fw13 a rozchodene elfy na elfpacku 2.3 z kibab.com ale mam problem s xtaskom. stale ked ho spustim tak chvilu ide a potom mi vypne fon. da sa s tym nieco urobit?
servisne menu som neskusal..co k tomu treba?
SIEMENS VEČNE ZIVÝ
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Thu Sep 27, 2007 6:46 pm    Post subject: Reply with quote
mainscreen je hlavni obrazovka... aplikujes patch "servisni menu" pak "vchod do native menu pri ###"... na hlavni obrazovce napises #### potom prejedes do LOGAL - das moznosti a enable ###... potom kdyz kdekoliv namackas ### otevre se ti hlavni menu... jesli tohle nechapes tak uz nevim jak ti pomoci
-> Nokia Lumia 800
PostPosted: Sat Sep 29, 2007 9:41 am    Post subject: Reply with quote
jj chapu tomu jem mi to nejde natukam #### na hlavni obrazovce ,,.a nic se nedeje .,. a patche mam ,.,. tak nevim kdeje problem :-( ,. a kaslu na to snazim se dat fw 25 tam pres WinSwup a nejak to nefakci .,,. :-( probehne pre-check ,.., nabehne Connection mobile .,. ,. mobil se vypne a v programu vypise Cant connect to Mobile with BootstrapLoader .,,. netusim co se deje snim
132978.34 SMM
PostPosted: Sat Sep 29, 2007 11:28 am    Post subject: Reply with quote
skus se podívat, jestli se ti ve výběru položek pro "moje menu" nebo na klávesu objevilo "developer" , "developer menu" nebo tak nějak...
jestli ne, tak jediná možnost je si to nastavit na nějakou klávesu přes DSE
(btw. myslim, že #### funguje až potom, co se aktivuje ### , admine )
PostPosted: Sat Sep 29, 2007 11:54 am    Post subject: Reply with quote
developer ani nic podobneho jsem nenasel a DSE ,.,.to je co ?? nejaky program nebo jako ?
a nejaka mozno jeste neni na minimalizaci javy ?
132978.34 SMM
PostPosted: Sat Sep 29, 2007 12:37 pm    Post subject: Reply with quote
ano,je to program wink
DSE.rar
ne, jiná možnost asi není Think jedině XTask nebo ### Rolling Eyes
PostPosted: Sat Sep 29, 2007 8:24 pm    Post subject: Reply with quote
nahral jsem si do mobilu FW25 vyskousel ty patche ,.., ono to frcelo .,,. jen mo nejak sblbnul cely mobil ,.nic neslo ,.,. nastavovat ,,. ani soubory nic ,.
a tak zase jsem si dal starsi verzi FW13 .,a uz to konecne chytlo ### ., protoe na nej je patch plus info zobrazuje teplotu baterie napěti ,.,. procenrta a sila signalu v dB ,..,a to na FW25 neni takovej patch
Dekuju moc všem za rady wink Dancing
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Sun Sep 30, 2007 8:10 pm    Post subject: Reply with quote
nj ale to ### musis aktivovat v #### wink
-> Nokia Lumia 800
PostPosted: Mon Oct 01, 2007 6:30 pm    Post subject: Reply with quote
hh dekuju moc ,. mi to uz frčelo ,. jenze jsem stim neco udelal a uz nic stoho nejde ,.., ale dekuju ,.,.
DarkLegion
1453.28 SMM
PostPosted: Mon Oct 01, 2007 10:06 pm    Post subject: Reply with quote
palucko wrote:
DSE.rar
musi to byt aj pre fw25..ja som ho mal a mal som to tam...potom mi blbli elfy a dal som i fw 13 a ten je super..a namiesto toho patchu som i dal elfa textinfo..ten toho zobrazuje ovela viac Dancing
SIEMENS VEČNE ZIVÝ
Goto page 1, 2  Next
Page 1 of 2
