jakarte kolemjdoucí
Posted: Sun Oct 07, 2007 12:13 pm Post subject: PDB reader |
Zdravim jaky pouzivate program na cteni PDB souboru??
Je nejaka alternativa k Mobipocket Readeru? |
Straces badatel
1013.16 SMM
pip@ administrátor
Posted: Sun Oct 07, 2007 1:06 pm Post subject: |
microreader  _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
SWalker začátečník
80.28 SMM
Posted: Sun Oct 07, 2007 1:37 pm Post subject: |
pridavam se k micro readeru. muzes menit velikot pisma, barvu pozadi, ma pekne vyresene zalozky.... jinak cte i txt. _________________ Alcatel OT 302,Ericsson R320S,Sony CMD-J6,Nokia 3310,Siemens SL45+128MB MMC,Siemens C55,Siemens S55+IQP 500,SonyEricsson T610,Siemens C65,Siemens CX65+DCA 510, Siemens S75 (fw47)+128 MB RS-MMC+DCA 510, Toshiba Portege G900 |
jakarte kolemjdoucí
Posted: Sun Oct 07, 2007 4:28 pm Post subject: |
Tak jsem zkusil MicroReader. A nejak se nedari ho nainstalovat.
Mam EF81. Instaluji pomoci JMI do mobilu.Vse probehne o.k., ale v aplikacich se MicroReader vubec neobjevi.
Kde je zakopany pes???
Ono to bude asi tim ,ze tenhle mobil asi nepodporuje? |
pip@ administrátor
Posted: Mon Oct 08, 2007 4:25 pm Post subject: |
je tam přímo psaný: Quote: | This is a beta test version based on version 1.4z3, supporting Siemens S75 and SL75.
It also run on most Siemens 65 platform phones, but NOT on the newer BenQ-Siemens phones such as SXG75 and EF81. | takže to fakt nepodporuje...  _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
Fijo666 rozumbrada
382.24 SMM
Posted: Wed Oct 10, 2007 7:17 am Post subject: |
mozno otazka mimo hrnca
ale mam knihy vo formate PDF ako ich prerobim do PDB??? alebo formatu aby sa dali citat v telefone?? dik
EDIT a este prosim kam mam skopirovat ten priecinok font co je v rare spolu s microreaderom _________________ N95, 2GB SD fw 30.0.015 + hack sw
SX45i + 32MB MMC
simp moderátor
Posted: Wed Oct 10, 2007 11:44 am Post subject: |
Začnu od konce.
Kam ho nahraješ, je jedno. Pokud jej nebudeš používat, ani ho do telefonu nahrávat nemusíš.
Pokud nelze všechen text z PDF dokumentu označit a normálně zkopírovat (třeba do Poznámkového bloku), je to problém. Existuje na to software, ale asi žádný není free. Například ABBYY PDF Transformer je poměrně spolehlivý, převádí téměř bez chyb a poradí si i s diakritikou.
EDIT: Pokud je tam číslo stránky, hlavička atd..., tak to asi nevyřeší ani další software (např. ten ABBYY PDF). _________________ M50 unlock java † → CX70 FW56 Elfpack 2.3 † → S65 FW58 Elfpack 2.3
Fijo666 rozumbrada
382.24 SMM
Posted: Wed Oct 10, 2007 3:31 pm Post subject: |
Dikes
ide mi skopirovat, ale sa potom zgrcne dokopy a ani odstavce nie su a pod...a navyse v niektorych PDF knihach je aj cislo strany +hlavicka a paticka a pod somariny a tie sa potom tiez spolu s textom skopiruju  _________________ N95, 2GB SD fw 30.0.015 + hack sw
SX45i + 32MB MMC
