:: View topic - Vydrz pamate
Vydrz pamate
Goto page Previous  1, 2
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Hardware
DarknessMaster
PostPosted: Thu Oct 11, 2007 11:44 am    Post subject: Reply with quote
odpoved je skvela vec, ale otazka jeste lepsi, proto jich neni nikdy dost Smile
>>>Darkness Master ReVeRsE Engineering<<<
>>>Everithing is possible<<<
Nokia 6150 Titanium SE --> Siemens M65 Aqua @ Dolomity DH crash --> Siemens M65 Antracite
MuF123
151.74 SMM
PostPosted: Fri Oct 12, 2007 3:37 pm    Post subject: Reply with quote
ok tak dalsia otazka: preco sa potom urcita cast pamate vola eeprom? nie je to vsetko na jednom chipe (flash)? zda sa mi ze aj eeprom sa zapisuje po blokoch takze je len taky nazov ale v skutocnosti eeprom je flash? aky ma to potom ucel (premenovanie)?
edit>
Code:
Memory Size 256 Mbit (32 MByte)
Data Bus: 16 Bit
Access Time: Initial access: 85 ns
Synchronous Burst Mode: 54 MHz / 14ns clock to data output
Asynchronous Mode: 85 ns
servisny manual
HTC Wizard Tuning - http://www.youtube.com/watch?v=ethB7XaeFz4
DarknessMaster
PostPosted: Sat Oct 13, 2007 7:47 pm    Post subject: Reply with quote
Presnou odpoved bych hledal v datasheetu k procesoru a manualech. jsou dve moznosti tusim...
Bud je to slovickareni, takze EEPROM a flash je v tomto pripade identicke medium, a sice FLASH 32MB...
Za druhe, mame tady jakousi FLASH 32MB + EEPROM interne zabudovanou v procesoru.... (momentalne netusim jestli tam neni interni i ta 32MB flash. )
kazdopadne by to mohl nekdo nastudovat, ted na to nemam moc casu...
jinak podle toho co jsem nasel tak prava EEPROM datumove starsi nez FLASH nikdy neumela a umet nebude zapis v blocich. tak jako FLASH nikdy nebude pristupovat bitove.
dneska se delaji tak rozsahle projekty ze ti nikdo EEPROM nikdo nepouzije, Kazdy ma v aplikaci FLASH, a proto se prejalo nazvoslovi EEPROM . To bude myslim kamen celeho problemu... ale mozna se mylim,,,
PostPosted: Sat Oct 13, 2007 7:58 pm    Post subject: Reply with quote
Wikipedia:
Flash
EEPROM
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Sat Oct 13, 2007 8:23 pm    Post subject: Reply with quote
vyraz EEPROM ktery pouzivame ve FF je cast dat ve flashi, ktera se kdysi zapisovala do EEPROM (jednoduche - ulozene nastaveni, atd.). dneska se tyto data zapisuji na urcitou adresu do flash pameti, a aby bylo jasno co tam je tak je to popsane jako EEPROM.
Koupím Siemens, který nemám.
MuF123
151.74 SMM
PostPosted: Sat Oct 13, 2007 8:25 pm    Post subject: Reply with quote
a je po diskusii Crying or Very sad diky Bonfire Applause
DarknessMaster
PostPosted: Sun Oct 14, 2007 11:07 am    Post subject: Reply with quote
Dobra prace chlapci. Ted uz to snad nikoho plest nebude... Very Happy
PostPosted: Sun Oct 14, 2007 11:31 am    Post subject: Reply with quote
Takze zamykame.
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Hardware All times are GMT + 1 Hour
Page 2 of 2
