:: View topic - @urel Mac OS S65v58
@urel Mac OS S65v58
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13, 14, 15  Next
Reply to topic     Forum Index -> Tuning
Malo by to vyznam???
Ano
85%
 85%  [ 47 ]
Nie
14%
 14%  [ 8 ]
Total Votes : 55
@urel
595.45 SMM
PostPosted: Sun Oct 14, 2007 7:36 am    Post subject: Reply with quote
Určite si musel niečo editovať alebo niečo...mňe tel. ide v pohode.
Siemens večne živý.
My tuning
@urel OS Hacker Edition EL71
@urel Mac OS S65
erikerik
PostPosted: Sun Oct 14, 2007 9:12 am    Post subject: Reply with quote
musel si nieco pomenit v nastaveniach...nikomu to nerobi len tebe...pisal som ti cez ICQ ze nemas chodit tam a nastavovat to co nevies...a ze ked nieco nevies mas napisat racej skusenejsiemu...dufam ze si tam nedaval dalsie patche ako si chcel?napis mi na ICQ...
SIEMENS C 75 , CX65 @ CX70 , S 65 , cx 75 , S75
SXG 75 ,
Nokia 5800 XM - šit
unci
PostPosted: Mon Oct 15, 2007 6:04 pm    Post subject: Reply with quote
ee nepatchoval som nwm co to je asi prehram znowa FF
erikerik
PostPosted: Mon Oct 15, 2007 6:13 pm    Post subject: Reply with quote
ok keby si mal problem som na ICQ...
SXG 75 ,
Nokia 5800 XM - šit
@urel
595.45 SMM
PostPosted: Tue Oct 16, 2007 1:46 pm    Post subject: Reply with quote
Určite si musel niečo editovať, lebo potom je zláštne že všetkým to ide v pohode en tebe to blbne.
Siemens večne živý.
My tuning
@urel Mac OS S65
erikerik
PostPosted: Tue Oct 16, 2007 2:17 pm    Post subject: Reply with quote
dnes budeme znovu nahravat TUNING...dufam ze mu to potom nebude robit...
SXG 75 ,
Nokia 5800 XM - šit
unci
PostPosted: Tue Oct 16, 2007 2:26 pm    Post subject: Reply with quote
fu to dufam aj ja Smile
erikerik
PostPosted: Wed Oct 17, 2007 6:48 pm    Post subject: Reply with quote
Us to ide...a vobec to nevypina , nezamrza... Applause Applause Applause
PS:musel si tam nieco spravit pred tym v nastaveniach ....
SXG 75 ,
Nokia 5800 XM - šit
unci
PostPosted: Wed Oct 17, 2007 7:58 pm    Post subject: Reply with quote
n mozno ale este to nie je skusene ci to na 100% nerbí
shuiyn
PostPosted: Sat Nov 03, 2007 2:39 am    Post subject: Reply with quote
http://www.4shared.com/dir/1687066/7eadb3e1/Uploads_Here_Uploads_Aqui_.html
pls can someone update on my Virtual HD a fullflash .bin with this tuning applyed ?
i really need it =( i did the winswup version but the S65 make a "beep" and dont turn on .... is easier for me just get the fubu and put the keys on it ^^
pls ~
*thanks in advance*
CX75sw25@10.44mb / Vista / Benchmark 1171 / 1GB mmc
@urel
595.45 SMM
PostPosted: Sat Nov 03, 2007 9:00 am    Post subject: Reply with quote
shuiyn wrote:
...i did the winswup version but the S65 make a "beep" and dont turn on ....
You need this phone s65 unlock through software PapuaUlitits.
Siemens večne živý.
My tuning
@urel Mac OS S65
braun21
324.74 SMM
PostPosted: Wed Nov 14, 2007 4:52 pm    Post subject: Reply with quote
Chtěl jsem si tento tng aplikovat a nejde.
Dal jsem do tel java aplikaci a vypočítal kódy.PU si je načetl a vypočítal skey.
Ten jsem zavedl a zkontroloval jestli bude factory mode.
Byl. Takže vše ok.
Následně nahrál tento winswup tng.Už jsem kdysi nějaký winswup nahrával a pamatuju si že po nahráti mi to napsalo že mám 3 minuty čekat a pak se mobil sám zapnul.
Tohle však teď s tímto tng bylo jinak.Vše se nahrálo az do konce a když to dojelo tak se objevila hláška:ERROR:NO WAITING STATED DATA a dál se nicnestalo.Po chvíli čekání jsem telefon odpojil a zkusil zapnout.Zablikala klávesnice a px.
Spojil jsem tedy tel s PU a zkusil vyměnit kódy dle návodu.
Dostal jsem mobil do servisního módu. A zmáčknul volbu FRIEA.LOG a chtěl přepsat kódy.
Ovšem jeden mi to nepřepsalo.
Napsalo to:BLOCK 76 SAVED
NOT CREATED THE BLOCK 5008!
Tak nevím co s tím mám dělat.
Mám úplně nejnovější PU a stále stejný problém.
Nevíte někdo co s tím?
S65fw58
(Mým nejvěrnějším a přitom nenáviděnym přítelem je PX)
erikerik
PostPosted: Wed Nov 14, 2007 4:55 pm    Post subject: Reply with quote
napis mi na icq...
SXG 75 ,
Nokia 5800 XM - šit
braun21
324.74 SMM
PostPosted: Sun Nov 18, 2007 3:19 pm    Post subject: Reply with quote
Tak se mi konečně povedlo dostat tenhle tng do tel.
Pohoda.
Vše jede v pohodě ale mám jeden problém.
Nemůžu dostat zpět do tel svůj adresář přes SiMoCo.
Dělal jsem zálohy tel seznamu snad tisíckrát,i vracel zpět a vždy vše proběhlo bez problémů ale teď s tímto tng mi to nejde.
Vůbec není aktivní nabídka "NAČÍST ADRESÁŘ TELEFONU"
Když dám obnova z disku tak se načte jen záloha do programu ale do tel ne.
Zkusil jsem i novou verzi a nejde.
Vzal jsem i druhý tel co mám cx65 a ten v pohodě komunikuje a seznam posílá oběma směry.
Nevím jestli třeba nějak simoco nezvládá název telefonu,že místo s65 je tam urel mac os.
Třeba někdo víte jak to udělat.
Dík za pomoc.
Ještě dodám že telefon i simoco jsou spojeny.
Systém souborů normálně kopírovat jde.
S65fw58
dak
121.04 SMM
PostPosted: Wed Nov 21, 2007 8:08 pm    Post subject: porat mi to nejde Reply with quote
zdravim,porat mi to tam nejde nahrat. pise to : Cant connect to Mobile with BootstrapLoader on Com 2. co s tiiim? diik
Reply to topic     Forum Index -> Tuning All times are GMT + 1 Hour
Page 11 of 15
