:: View topic - gastroskop
gastroskop
DarkLegion
1453.28 SMM
PostPosted: Fri Oct 26, 2007 4:40 pm    Post subject: gastroskop Reply with quote
tak som minule cumel do mrtvej cx75 a povolil uzdu fantazii a napadlo ma ci by sa to nedalo nejak urobit. kablik pripajany do fonu cez konektor a na druhom konci kamera z nejakeho telefonu...nieco na sposob ako tie pripajacie fotaky k s55 c60 a64...
je to technicky realizovatelne?
prip. este ma zaujima ci sa da vyoperovany fotak nejak osadit do schemy a urobit z toho napr webkameru...
podobne aj z infraportu urobit infrak pre pc
len chcem vediet ci sa to da a ked hej tak aka je schema..hned by som sa do toho pustil Angel
SIEMENS VEČNE ZIVÝ
39.00 SMM
PostPosted: Fri Oct 26, 2007 4:42 pm    Post subject: Reply with quote
schema mas zde http://www.siemensmania.cz/download.php?file=/smanualy/2.5_CX75_M75_R1.0.ZIP
DarknessMaster
PostPosted: Thu Nov 08, 2007 5:44 pm    Post subject: Reply with quote
nejsem si jisty webkamerou ale s tim chipem epson by z toho sla udelat kamera s displayem ktery by reatime ukazoval co snima a celkem "jednoduse"...
>>>Darkness Master ReVeRsE Engineering<<<
>>>Everithing is possible<<<
Nokia 6150 Titanium SE --> Siemens M65 Aqua @ Dolomity DH crash --> Siemens M65 Antracite
MuF123
151.74 SMM
PostPosted: Thu Nov 08, 2007 9:53 pm    Post subject: Reply with quote
skoro som zacal zhanat nejaku zvysnu kamerku.. az som si vsimol tie uvodzovky
HTC Wizard Tuning - http://www.youtube.com/watch?v=ethB7XaeFz4
DarkLegion
1453.28 SMM
PostPosted: Mon Nov 12, 2007 1:51 pm    Post subject: Reply with quote
..uz len vyspekulovat prepojenie s displejom...ktory cip riadi vykreslovanie na displej a ktory snimanie?
SIEMENS VEČNE ZIVÝ
stream
5506.00 SMM
PostPosted: Mon Nov 12, 2007 2:36 pm    Post subject: Reply with quote
juuu tak řekni jak
Trance, disko forever :-)
I love mobile tuning ...
DarknessMaster
PostPosted: Sat Nov 17, 2007 7:23 pm    Post subject: Reply with quote
v tom datasheetu co je tady prilozeny je napsane u toho chipu epson ze umi bud posilat data k dalsimu zpracovani v sgoldu nebo je umi primo posilat na display. takze vzit vystup na desce a naplacat tech 8 dratu na display, teoreticky by to melo jit, jeste musis zjistit jake data mu poslat nebo jaky pin prepina ty rezimy, ale datasheet by to mel mit vsechno. takze vzhuru do zkouseni. Smile
stream
5506.00 SMM
PostPosted: Sat Nov 17, 2007 9:11 pm    Post subject: Reply with quote
to zní hezky ... mám doma pár displayů a kamer tak bych to rád zkusil Razz
DarknessMaster
PostPosted: Sat Nov 17, 2007 9:22 pm    Post subject: Reply with quote
urcite pak dej vedet. kouknu co mam doma a taky se zabavim az bude cas.
DarkLegion
1453.28 SMM
PostPosted: Thu Nov 29, 2007 4:08 pm    Post subject: Reply with quote
este mam k tomu otazku...s cim sa da vyoperovat ta kamera?
da sa to indukcnou pajkou 0,5mm alebo radsej horkovzduchom?
SIEMENS VEČNE ZIVÝ
