:: View topic - Want to Ask : Does Elfpack support transparent image?
Reply to topic     Forum Index -> Non Czech Languages Here
delpierwin
519.20 SMM
PostPosted: Fri Dec 28, 2007 2:52 am    Post subject: Want to Ask : Does Elfpack support transparent image? Reply with quote
Hello, i'm just asking whether if Elfpack support transparent image? I use Elfpack 2.3, and i'm applying some elf like sMenua and aclock that i'm set it to use transparent image. But, sadly, it doesn't work.. Crying or Very sad
Does anyone had a clue to use transparent image on elfpack.
Thank You
SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM
delpierwin
519.20 SMM
PostPosted: Fri Dec 28, 2007 9:11 am    Post subject: Reply with quote
For the reason, i see Pip@'s SL91 TnG, right on this caps :
Seems that aclock .png's clock pictures looks transparent above
wallpaper.
and i'm wondering how could D4X letter to be look like that Think , in addressbook i mean.
Does anyone had any explanation?
SiemensXP | My Blog
132978.34 SMM
PostPosted: Fri Dec 28, 2007 9:16 am    Post subject: Reply with quote
Elfpack supports transparent images. And semitransparent too (alpha channels)..
In which program are you creating pictures? I´m using Photoshop CS2 and it works...
//D4X Letter is from D4X tuning, it´s one letter changed by Siemens CE
delpierwin
519.20 SMM
PostPosted: Fri Dec 28, 2007 9:47 am    Post subject: Reply with quote
Thanks for reply Pip@, same as You, i use Photoshop CS2 too. I set image transparently, but after applying not as good as i want, but...firstly it looks transparent but after several second, it's blurring then go back not transparent. Do i have to set parameters in Elfpack, if any?
Sorry, add info, I'm not include swi.lib to my handset, cause without it, everything works fine. Could it be the cause?
About alpha channel how must i set up image in Photoshop? I often made it transparently by changing blending option oppacity just like that, no other less Very Happy
SiemensXP | My Blog
delpierwin
519.20 SMM
PostPosted: Fri Dec 28, 2007 3:02 pm    Post subject: Reply with quote
Desperate on searching alpha transparency on Photoshop CS2 Crying or Very sad
Please could someone show me how to make it.
Btw, Pip@ thanks for Tahoma fonts, it's really nice look on my S75, my friends in Indonesia, loves to apply it Very Happy
SiemensXP | My Blog
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
