delpierwin badatel
 Joined: 27 Dec 2007 Posts: 146 Location: Sukabumi, Republic of Indonesia
519.20 SMM
Posted: Thu Jan 24, 2008 8:54 am Post subject: |
Ooops, i think that's the point Zeus, i use 450100 firmware it's Lg01. Okey i'll made my self then. _________________ SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM |
truhlik elfmaster
8069.50 SMM
Posted: Thu Jan 24, 2008 9:35 am Post subject: |
Zeu5 wrote: | Hello
I am an author of this program
sometimes I visit this forum and can read messages on english
What you want to see in new version of the E71sGC?
so except
-searching for free place in FF, as in SPC3 for making GraphPatch
-full translation dialogues
that i try to add..
when i finish translating to English, i can add CZ language with anybody's help from this topic, i write there when it is necessary  |
hi,
my suggestion: you should add support for x75 series & NewSgold series.
I think, this is really good soft and this support helps many people.
brgds _________________ Motorola AMIO --> SL45i v56 tuned --> S75 v47 + FFS v40 + map v40 + Flash Patch
Svatky - 06
DApp - 055b
Elfpack.wz.cz Elfpack česky by truhlik
http://sl45i.wz.cz/ SL45i patche |
Zeu5 kolemjdoucí
 Joined: 30 Dec 2006 Posts: 9 Location: Russia, 64region
10.10 SMM
Posted: Thu Jan 24, 2008 6:09 pm Post subject: |
truhlik wrote: | you should add support for x75 series & NewSgold series
Yes, it is in my plans for the future
i want add x65series(and CX75, M75, C75 etc) and if s75 & sl75 have structure such as x65 they will be added too
so i start research pictures structure in PITmaker, which support x65 and s75. you can download this programm from my site (www.skypiece.narod.ru). but PITmaker had many bugs  |
delpierwin badatel
519.20 SMM
Posted: Fri Jan 25, 2008 10:12 am Post subject: |
Hello Zeus, why i couldn't found english drop down choice for language in the top right of it? Is there any download link for English language support? _________________ SiemensXP | My Blog
Zeu5 kolemjdoucí
10.10 SMM
Posted: Fri Jan 25, 2008 1:05 pm Post subject: |
delpierwin wrote: | Is there any download link for English language support? |
Use this URL for download always latest version  |
Duku uživatel roka 2008
 Joined: 18 Dec 2004 Posts: 1027 Location: Liptovský Mikuláš Phone: EL71v45 28.71 SMM
Posted: Fri Jan 25, 2008 4:29 pm Post subject: |
Hi. Can you add support for Czech and Slovak chars in loading BMPs from folder?
Code: | á, ä, č, ď, é, ě, í, ľ, ĺ, ň, ó, ô, ř, ŕ, š, ť, ú, ů, ý, ž |
_________________ EL71 Black FW45 + Kingston 2GB + DCA-110 + DCA-140 + HHS-150
>Daruj krv< |
kozino věrný diskusník
2156.42 SMM
Příspěvky na SM: 160,- |
thiagom začátečník
Joined: 15 Sep 2004 Posts: 38 Location: Rio de Janeiro - Brasil
Posted: Fri Jan 25, 2008 5:29 pm Post subject: |
Duku wrote: | Hi. Can you add support for Czech and Slovak chars in loading BMPs from folder?
Well, if you can add support for Portuguese Brazilian chars too...
"áÁ,àÀ,éÉ,êÊ,óÓ,íÍ,úÚ,îÎ,çÇ,ãÃ,õÕ,ûÛ.."etc |
Zeu5 kolemjdoucí
10.10 SMM
Posted: Fri Jan 25, 2008 6:23 pm Post subject: |
hmm
if my prog open your fullflash then all pictures in all fonts may be changed..(if its size<=current PICture size)
put on some folder *.bmp files with necessary numbers and use "Load BMPs"
that all..
principle of the adding from folder - prog has trying open BMPs from 0001.bmp to maxNum picture in current font, if file named xxxx.bmp exists then it open and change current pic or not change (see above)
May be, I has not correct understood your request?.. |
Posted: Fri Jan 25, 2008 6:47 pm Post subject: |
I know in english only few words, but i try it
For example "á" in FF has number 0161, but "á" from font2png has number 0225.
I know, change belike dont need E71seriesGC, but font2png....I just trying it  _________________ EL71 Black FW45 + Kingston 2GB + DCA-110 + DCA-140 + HHS-150
>Daruj krv< |
Zeu5 kolemjdoucí
10.10 SMM
Posted: Fri Jan 25, 2008 10:06 pm Post subject: |
Duku wrote: | For example "á" in FF has number 0161, but "á" from font2png has number 0225. |
Yes, sGC not moreover here..
you need configure font2png
for example:
charsmod.ini
[RUSSIAN_CHARSET]
;верхний регистр
192=446
193=447
194=448
195=449
you must use -
[CZECH_CHARSET]
;uppercase
161=225
162=226
163=227
164=228
But font2png not have "CZECH_CHARSET", you need ask SilentDek for add it..but he has accidentally destroyed sources and not so will soon write new
so..you can try leave "RUSSIAN_CHARSET", modify codes and choose RUSSIAN_CHARSET in program and press "START(BMP)". Good luck! |
Zeu5 kolemjdoucí
10.10 SMM
Posted: Sun Jan 27, 2008 9:58 pm Post subject: |
update - 27.01.2008, E71seriesGC 0.1.790
+searching for free space in fullflash for graf. patches
+support png (necessary bend nconvert). Drop nconvert to sGC folder
+interface and code, possibility of the save settings
If you want to translate E71sGC on your national language download English LangFile _________________ SiemensGraphicChanger Developer
screen |
Sefinko elfmaster
6980.53 SMM
delpierwin badatel
519.20 SMM
Posted: Mon Jan 28, 2008 2:51 am Post subject: |
Zeu5 wrote: | delpierwin wrote: | Is there any download link for English language support? |
Wow thanks a bunch Zeus  _________________ SiemensXP | My Blog
delpierwin badatel
519.20 SMM
Posted: Tue Feb 12, 2008 11:01 am Post subject: |
Looks like link was down
EDIT: Sorry, it's working again now...  _________________ SiemensXP | My Blog
