:: View topic - PlayEX, BREW MP3 Player with Shuffle, Repeat
Goto page Previous  1, 2
pornol
127.76 SMM
PostPosted: Mon Mar 24, 2008 10:50 pm    Post subject: New skins for PlayEX Reply with quote
New skins for playEX from Polish Users:
http://ef81.info/viewtopic.php?t=3637
If you want siemens phone contact me:)
RDT
6964.82 SMM
PostPosted: Mon Mar 24, 2008 11:05 pm    Post subject: Reply with quote
Wow, very nice skins Applause!
xaunicky
298.36 SMM
PostPosted: Wed Mar 26, 2008 9:11 pm    Post subject: Reply with quote
Má někdo tušení, jestli půjde přehrávač nějakým způsobem dostat do EF91? Think
A35 + MT50 + Telestar T168 + SXG75 white + IMS-700 + EF81/FW58 CZ + 1GB microSD Kingston + EF91 fw1.11 + 1GB microSD Kingston + HHB-750
kraze1984
155.88 SMM
PostPosted: Wed Apr 09, 2008 1:26 pm    Post subject: Reply with quote
You have to change the ESN (not IMEI) of your device.
Try to do this with Q X D M.
Alternatively you can replace the content of $SYS.ESN in the folder nvm\ of your phone with the string mentioned in the FAQ.
But - you will have to have possibility to access App Manager on your phone. I would suggest to search any hidden menus.
BEZY
81.16 SMM
PostPosted: Tue Apr 22, 2008 7:53 pm    Post subject: Reply with quote
verze 0.1 je už vážně dobrá, nepadá, přehrává pěkně, podporuje konfigurační soubory Applause
http://www.bezysoftware.net
Brew Mobile Commander 2.0
132978.34 SMM
PostPosted: Wed Apr 23, 2008 3:17 pm    Post subject: Reply with quote
nechtěl by o tom někdo napsat článek? ať pořád nevychází jenom články o elfech Smile
RDT
6964.82 SMM
PostPosted: Wed Apr 23, 2008 7:17 pm    Post subject: Reply with quote
Taky jsem o tom přemýšlel. Ale nebude lepší počkat ještě na nějakou vyšší verzi? Think
kraze1984
155.88 SMM
PostPosted: Thu May 08, 2008 10:24 am    Post subject: Reply with quote
Version 0.15 is out
Quote:
Fixed: Hidden files included in playlist now.
New: Drawing stereo mode, frequency and bitrate for mp3 and wav files.
New: Drawing mp3tag instead filename in Player-Name view for mp3 files.
New: Saving player mode after call. Don't start play, if stop or pause mode was before call.
New: Resuming current track after call (incoming/outgoing)
Fixed: Losing position in playlist after turning off random mode.
New: New config key INITIAL_RANDOM_MODE.
New: Try to start next song if current is bad.
Also another smallest, invisible internal fixes and optimizations.
(p.s. just look in latest pages, i do not always have time to update the first page of the thread).
Page 2 of 2
