rotar kolemjdoucí
88.54 SMM
Posted: Thu Sep 09, 2010 10:19 pm Post subject: problems with sl75 |
i have some problems with sl75..the phone is very slow doesn't work very well..he suffers many blocks while working.. i can't activate menu from the key..almost every operation i try to do the phone says "please wait" for a very long time..so i have to take out the battery..
firmware version is 13...
what can i do now??
thanks |
NoviS řád zlaté antény
 Joined: 01 Aug 2008 Posts: 857 Location: Praha Phone: EF81 144510.50 SMM
Příspěvky na SM: 115,- |
Posted: Fri Sep 10, 2010 6:51 am Post subject: |
I can recommend you to update firmware in your SL75 to the latest version. You can find it here on Siemensmania in section Firmware. The latest SL75 FW here is 52. For the update, you will need a service cable DCA-510. _________________ A52 -> M65† -> SXG75† -> SK65 -> S75 -> SX1 -> SK65 + S75 -> SL75, SK65, S68, S65, EF81... prostě pořád nějaký SIEMENS
->MOJE SBÍRKA<- |
rotar kolemjdoucí
88.54 SMM
Posted: Fri Sep 10, 2010 7:53 am Post subject: |
ok..thanks
is there any thread where i can find how to do the upgrade???
thank you again |
Posted: Fri Sep 10, 2010 8:17 am Post subject: |
If you have the cable, you can just download the fw version you want (higher the better), run it on your computer and follow the instructions it will give you. _________________ A52 -> M65† -> SXG75† -> SK65 -> S75 -> SX1 -> SK65 + S75 -> SL75, SK65, S68, S65, EF81... prostě pořád nějaký SIEMENS
->MOJE SBÍRKA<- |
rotar kolemjdoucí
88.54 SMM
Posted: Fri Sep 10, 2010 10:26 am Post subject: |
NoviS wrote: | If you have the cable, you can just download the fw version you want (higher the better), run it on your computer and follow the instructions it will give you. |
ok noviS thank you very much..i look for the cable now and then start working..
herry_potter kolemjdoucí
 Joined: 13 Jan 2006 Posts: 27 Location: West Java, Indonesia
63.58 SMM
Posted: Fri Sep 10, 2010 1:28 pm Post subject: |
Hi Rotar, if you have difficulties to get dca-510, then visit www.germanmobilephone.com. They have some stock. _________________ E71 SL91 E81 M81 M7 SXG75 S75 M75 M65 CXT65 M55 ME45 SL45i SL45 SL42 SX1 S25 S10D S6
DCA-500, DCA-510, DCA-540, DCA-100, DCA-140 DIP-100 |
rotar kolemjdoucí
88.54 SMM
Posted: Fri Sep 17, 2010 1:20 pm Post subject: |
thanks everyone guys!!!
i did it!!!
my sl75 came back to life!!!
i tried to use winswup also for my c60 but the phone has got a big problem..it doesn't turn on..so winswup can do nothing..when i try to turn it on a blue screen appears and a strange sound then it turns off..it says couldn't ping mobile..
any suggestions??
EDIT:by skipping the precheck control with winswup the upgrade starts but when it comes to its end the phone doesn't turn on all the same..
rattle-snake všeználek
15518.64 SMM
Příspěvky na SM: 460,- |
Posted: Fri Sep 17, 2010 2:53 pm Post subject: |
Hello rotar! Nice to read, that your SL75 is alive again. To your problem with C60 - create please new topic in the section x60 and older models....  _________________ Siemens mobile stále s námi!
rotar kolemjdoucí
88.54 SMM
Posted: Fri Sep 17, 2010 4:20 pm Post subject: |
rattle-snake wrote: | Hello rotar! Nice to read, that your SL75 is alive again. To your problem with C60 - create please new topic in the section x60 and older models....  |
hi rattle-snake!!
thank you very much again..my great silver sl75 is living again ..
i've just solved even my problems with c60 by using joker..simply service mode and format everything..
great forum and great work from you guys
