:: View topic - Siemens SP65
Siemens SP65
stav1988
30.46 SMM
PostPosted: Fri May 13, 2011 11:56 am    Post subject: Siemens SP65 Reply with quote
1. What software i have to use for transfer music, movies, pictures, java, etc. and how? It work on windows 7?
2. The difference between SP65 and S65 is only the camera? otherwise have the same characteristics, ex: processor speed, supports the same extensions, etc?
3. I found here that can put mp3s on it http://sandstormrs.proboards.com/index.cgi...&thread=588 someone succeeded? can even tell me what program i need, where i download ELF? can explain me step by step how?
4. I have 48 firmware on it, the last is 50, how to update it?
5 .I need the original cable to update the firmware phone?
Thanks verry much!!! my SP62 is new i want to join it.
144510.50 SMM
PostPosted: Fri May 13, 2011 8:52 pm    Post subject: Reply with quote
1) You can transfer everything via memory card reader, i think every SD card reader supports (RS-)MMC.
2) Yes, i think that camera is the only difference. But if you think for example patches, you have to find patches which were made especially for your phone and FW version.
3) I don´t know, I hope that somebody else will help you with this. Tutorial how to play MP3s on x65 is HERE.
4) It is simple, instructions are HERE.
5) No, you don´t need original cable for FW update, but it has to be marked as DCA-510. You may see what type of cable you have after pressing *#06# -> more, under Acc. plugged in:...
stav1988
30.46 SMM
PostPosted: Sat May 14, 2011 2:00 pm    Post subject: Reply with quote
My cable model is KQ-U8A when i press *#06* Acc says... none, that i think my cable is not support. what to do now ?
you have an id messenger to discuss?
144510.50 SMM
PostPosted: Tue May 17, 2011 10:31 pm    Post subject: Reply with quote
To find what kind of cable do you have is neccessary to plug the cable into both computer and phone... maybe the mistake is here Smile .
As a software you may try SiMoCo (from here), i have it already installed on Win7.
I have only ICQ, but, however, I wrote here everything I know Mr. Green .
