:: View topic - Ktore pini to su?
Ktore pini to su?
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 4:33 pm    Post subject: Ktore pini to su? Reply with quote
Ktore pini mam zalepit aby mi isla komunikacia s kablom pls poradte.Dieg0
Orpheus
14900.34 SMM
PostPosted: Fri Dec 31, 2004 4:35 pm    Post subject: Reply with quote
A jaky mas?
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 4:37 pm    Post subject: Reply with quote
Pardon nie zalepit ale zapojit na ake pini mama zapojit prud 1 a 2 alebo 1 a 3?Dieg0 DCA500
Guest
PostPosted: Fri Dec 31, 2004 4:50 pm    Post subject: Reply with quote
Neni to nahodou napsany v tom navodu???????
oookoook
veterán
veterán
PostPosted: Fri Dec 31, 2004 4:51 pm    Post subject: Reply with quote
Zapomnel jsem se prihlasit. Embarassed
Oook Oook!
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 4:52 pm    Post subject: Reply with quote
v navodu to neni Sad
oookoook
veterán
veterán
PostPosted: Fri Dec 31, 2004 4:57 pm    Post subject: Reply with quote
A na jakej navod koukas? Co se vlastne snazis udelat? A co ti s DCA-500 vlastne nefunguje? Tobe vadi, ze neni servisni, ne? A kde jsi vzal tu jistotu, ze ho na DCA-510 predelas? Uz tady o tom preci byla jedna diskuse - s tema cinchama...
Oook Oook!
Orpheus
14900.34 SMM
PostPosted: Fri Dec 31, 2004 5:02 pm    Post subject: Reply with quote
Mna by prerobenie DCA-500 na servisny tiez zaujimalo. Trieda X65. Viem ze Treba dat napetie 3-4,5V do 1 a 2 pinu ci tak a este zapojit 2 15k rezistory dakde
oookoook
veterán
veterán
PostPosted: Fri Dec 31, 2004 5:08 pm    Post subject: Reply with quote
Tak to s tema rezistorama bylo v tom navode tady: http://www.siemensmania.cz/content.php?id=152
A je tam napsano: Aby telefón rozpoznal aj váš kábel, musíte prispájkovat dva rezistory s hodnotou 15 kiloohmov z pinu 5 a 7 na pin 2 (uzemnenie). V nasledujúcom obrázku je zapojenie schématicky znázornené.
Co je za problem?
Oook Oook!
Orpheus
14900.34 SMM
PostPosted: Fri Dec 31, 2004 5:18 pm    Post subject: Reply with quote
No, mne na org. DCA-540 ide z konektora 7kablov. A na konektori do mobilu to nemam tak lahko zapojene. Ku vsetkym pinom mam zaletovanu dosku s neakymi rezistorimi a nakonci dosticky ide 7kablikov do kablu na Com.
