:: View topic - Dotaz ....
Dotaz ....
Methoz
Guest
PostPosted: Sun Jan 09, 2005 1:40 am    Post subject: Dotaz .... Reply with quote
Hi! Mam s65 a zajimalo bz me, jestli je program na prevod videii do 3GPP abych si je pak mohl sam delat a davat do mobilu. Diky
Orpheus
14900.34 SMM
PostPosted: Sun Jan 09, 2005 9:39 am    Post subject: Reply with quote
Nokia Multimedia Converter 2.0
JenaM
5904.88 SMM
PostPosted: Sun Jan 09, 2005 9:40 am    Post subject: Reply with quote
nevím jestli je přimo nejaky prevodnik do 3gp ale je prehravac ktery ti je prehrava ale jen v PC coz ti asi bude na nic....ale myslim ze je zbytecne neco takoveho shanet protoze kvalita displeje neni tak sqela abys tam prihraval vydea!
No11
PostPosted: Sun Jan 09, 2005 12:07 pm    Post subject: Reply with quote
u siemensu ne ale znáte telefon NECe616 má rozlišení vide 640x480 v 32bit...
mot m3888=>mot t2288R => N3310=>N3330=>N3410=>N6310i =>CT65 fw12, FW25,Clear T-mobile, FW33,=>M65 FW12,FW25 patched,FW33 patched, FW41 patched, FW 43 PAtched
PostPosted: Mon Jan 10, 2005 1:38 pm    Post subject: Re: Dotaz .... Reply with quote
Program PV author...ja nato na stranke clanok.
Methoz
Guest
PostPosted: Mon Jan 10, 2005 1:52 pm    Post subject: Reply with quote
Stahl sem si MMConverter a bohate mi vyhovuje...Ale dik za rady
