Stifler3 kolemjdoucí
Posted: Mon Jan 10, 2005 8:16 pm Post subject: KABEl FW |
Mam dotaz kamos ma CX65 a ma k nemu kabel ..Slo by pres ten jeho kabel mi prehrat FW..přecejenom nabiječka mi funguje i z C62 ..Jo a jste se si jisti ze tim nestratim zaruku |
Orpheus čestný člen
Joined: 25 Dec 2004 Posts: 3637 Location: Bratislava(SK)
14900.34 SMM
Posted: Mon Jan 10, 2005 8:55 pm Post subject: |
A jaky typ to je?! |
Guest
Posted: Wed Jan 12, 2005 9:03 pm Post subject: |
no a jaky mas ty typ telefonu???jinak prehranim FW bys zaruku ztratit nemel!!! |
No11 badatel
Posted: Wed Jan 12, 2005 10:52 pm Post subject: |
a jaký typ kabelu.. Modli se aby ne DCA540..  _________________ mot m3888=>mot t2288R => N3310=>N3330=>N3410=>N6310i =>CT65 fw12, FW25,Clear T-mobile, FW33,=>M65 FW12,FW25 patched,FW33 patched, FW41 patched, FW 43 PAtched |
Womanizer badatel
 Joined: 06 Oct 2004 Posts: 134 Location: Uherský Brod
Posted: Thu Jan 13, 2005 4:16 am Post subject: Re: KABEl FW |
Stifler3 wrote: | Mam dotaz kamos ma CX65 a ma k nemu kabel ..Slo by pres ten jeho kabel mi prehrat FW..přecejenom nabiječka mi funguje i z C62 ..Jo a jste se si jisti ze tim nestratim zaruku |
Zkus si nainstalovat ovladace k tomu kabelu a pripoj telefon.Potom namackej na mobilu *#06# ....pak zmackni Vice a najed si uplne dolu.Je tam polozka Acc.: Pokud tam budes mit plugged in:DCA 510,tak mas vyhrano a kabel je servisni.Myslim,ze origo FW by mel jit i s DCA 500.Pokud tam mas DCA 540,tak ti to nepujde.. _________________ N7110=>N3310=>SonyCMDJ7=>SIEMENS M65 |
No11 badatel
Posted: Thu Jan 13, 2005 4:47 am Post subject: |
ano mam orig DCA 500 a FW jde taktéž _________________ mot m3888=>mot t2288R => N3310=>N3330=>N3410=>N6310i =>CT65 fw12, FW25,Clear T-mobile, FW33,=>M65 FW12,FW25 patched,FW33 patched, FW41 patched, FW 43 PAtched |
Dieg0 siemensmaniak
 Joined: 08 Nov 2004 Posts: 2937 Location: SR Lipt. Mikulas Telefon: Siemens C65
19990.28 SMM
Posted: Thu Jan 13, 2005 6:42 am Post subject: |
Prosim ako prosim prosim ako nahram FW cez DCA500 do mojej C65ky pls pls pls pls Chcel by som FW33 aby som moholo 3gp-cka prehravat pls pls diki vopred za odpoved.Dieg0 _________________ ...odstraneno - prilis velky obrazek... |
Dieg0 siemensmaniak
19990.28 SMM
Posted: Thu Jan 13, 2005 1:44 pm Post subject: |
PROSIM PORADTE PLS AKO MAM PREHRAT FW NA 33 PROSIM PORADTE AJ DOSTUPNE PROGRAMY A TAK MAM ORIGINAL DCA 500.Dieg0 _________________ ...odstraneno - prilis velky obrazek... |
Krokodýl čestný člen
Posted: Thu Jan 13, 2005 1:52 pm Post subject: |
Dieg0 wrote: | PROSIM PORADTE PLS AKO MAM PREHRAT FW NA 33 PROSIM PORADTE AJ DOSTUPNE PROGRAMY A TAK MAM ORIGINAL DCA 500.Dieg0 |
Se zapnutým telefonem spustíš update. Musíš mít nabitou baterii na plno. _________________ Zálohovat, zálohovat, zálohovat!!!
Dieg0 siemensmaniak
19990.28 SMM
Posted: Thu Jan 13, 2005 2:05 pm Post subject: |
A prosim te brouzdal jsem na SM a nikde jsem to nenasle nemoh by si mi to popsat prosim moc me to laka mat tu 33 FW.Potom se chci zeptat stracim tim zaruku?A jeste ze jakej program pouzit a jak si udelat zalohu.Dieg0 _________________ ...odstraneno - prilis velky obrazek... |
BEZY čestný člen
81.16 SMM
Posted: Thu Jan 13, 2005 2:08 pm Post subject: |
Dieg0 wrote: | A prosim te brouzdal jsem na SM a nikde jsem to nenasle nemoh by si mi to popsat prosim moc me to laka mat tu 33 FW.Potom se chci zeptat stracim tim zaruku?A jeste ze jakej program pouzit a jak si udelat zalohu.Dieg0 |
Jak jakej program? Normálně stáhni ten FW-je to exe soubor, ten spustíš a nahraje ti do tlf. novej FW. Zálohu uděláš přes V-klay, jenže je se servisnim kabelem. _________________ C35i -> M35i -> M50 -> CX65 -> SX1McLaren -> SXG75 -> HTC HD
http://www.bezysoftware.net
Brew Mobile Commander 2.0 |
Dieg0 siemensmaniak
19990.28 SMM
Posted: Thu Jan 13, 2005 2:09 pm Post subject: |
A kdyz prehraju FW nestracim zaruku? _________________ ...odstraneno - prilis velky obrazek... |
BEZY čestný člen
81.16 SMM
Posted: Thu Jan 13, 2005 2:13 pm Post subject: |
Bez servisního kabelu si kompletní zálohu neuděláš. A asi jsi špatně hledal nebo vůbec. SM není jenom fórum http://www.siemensmania.cz/firmware.php _________________ Zálohovat, zálohovat, zálohovat!!!
Dieg0 siemensmaniak
19990.28 SMM
Co je to ofiko?A kolik se nahrava?A kdyz chci naspet tak muzu znova s DCA500 na FW25?.Dieg0 _________________ ...odstraneno - prilis velky obrazek... |
