:: View topic - x65 .... změna ikon menu
Goto page Previous  1, 2, 3 ... 12, 13, 14 ... 22, 23, 24  Next
tofinkooo
PostPosted: Tue Jan 18, 2005 7:33 pm    Post subject: Reply with quote
takze na umiestnenie odkazuje main.fs....hmm.. po uprave moze main.fs odkazovat na subory...no pekne..este stale ma ignoruje. necham ho tak, mozno sa casom umudri.
tofinkooo
PostPosted: Tue Jan 18, 2005 10:45 pm    Post subject: Reply with quote
na akom principe funguje "Superfast menu"???
ved to iba zapise jednu hodnotu /08C33D4: 73B586 C7A084/ a je to rychle. preco to siemensaci hned nespravili?????
PostPosted: Wed Jan 19, 2005 1:30 pm    Post subject: Reply with quote
Arrow http://m65.xost.ru/downloads/infinity.zip
Arrow http://www.stefankies.de/handy/iconsc_s_b.zip
tofinkooo
PostPosted: Wed Jan 19, 2005 1:33 pm    Post subject: Reply with quote
heh...to tak pre nejake babo :-P
BEZY
81.16 SMM
PostPosted: Wed Jan 19, 2005 2:54 pm    Post subject: Reply with quote
Tím se dostaněš do servisního menu, který je rychlejší než to standartní. Ale to sem moc nepatří...
http://www.bezysoftware.net
Brew Mobile Commander 2.0
tofinkooo
PostPosted: Wed Jan 19, 2005 3:35 pm    Post subject: Reply with quote
haa...takze v tom je ten hacik. preplao sa to na ine menu. takze preto, sa mi nedaju menit ikonky..nie??
PostPosted: Wed Jan 19, 2005 3:40 pm    Post subject: Reply with quote
Nie,tam Ti ikonky menit nepojdu.Nie je to klasicke flexmenu a vola sa to Native menu.
tofinkooo
PostPosted: Wed Jan 19, 2005 3:58 pm    Post subject: Reply with quote
no fajn..uz mi to ide..ale je to pomale :-((( a to sa mi nepaaci. potrebujem rychly phon, nie taku spomalenicu...skaredy siemens
PostPosted: Thu Jan 20, 2005 8:03 am    Post subject: Reply with quote
Pomale?Telefon nie je pocitac P4 s 1024MB RAM-kou.
Myslim si,ze to menu ma na telefon celkom slusnu rychlost.Hlavne oproti starsim modelom.
tofinkooo
PostPosted: Thu Jan 20, 2005 9:13 am    Post subject: Reply with quote
jasnacka..spomalene. v porovnani so starsimi modelmi mozno, ale na ine telefoniky (od inych vyrobcov) sa to nechyta.
ce to rychlu potvorku s velkym displayom, aby som z neho mohol lahko odpisovat pofotene vypracovane otazky :-P, ked som na skuske...
Naughty
PostPosted: Wed Jan 26, 2005 7:54 pm    Post subject: nemuzu najit flexmenu Reply with quote
Zdravím všechny kolem jdoucí, kteří budou jistě vědět, proč nemůžu najít v seimensu cx65 flexmenu a v něm main.fs???Skryté soubory vidím dostanu se až do japp, ale dál tam mám jen wcinit. Tak jsem tam zkusil udělat soubor flexmenu a do něj jsem nahrál nové ikony i s main.fs a vypnul a zapnul mobil, ale nic se nestalo... Pls, kde dělám chybu?? Brick wall
Dík
PostPosted: Wed Jan 26, 2005 11:50 pm    Post subject: Re: nemuzu najit flexmenu Reply with quote
Dík
Pokud by jsi neměl v Config\japp\FlexMenu tak by ti nemohlo fungovat grafické menu!!
Prohledáváš složku Data\Config\japp!! Tam to nepatří, pokud nevidiš disk Config nemáš řádně otevřené skryté disky!!!
glaxo
PostPosted: Sat Jan 29, 2005 7:33 pm    Post subject: ikona nastavenia mi nejde Reply with quote
neviete co s tym aby to slo?klikam na nu a podmenu mi neotvori, mam cx65/fw25
PostPosted: Mon Jan 31, 2005 12:55 pm    Post subject: Reply with quote
Arrow http://forex.dinohost.ru/soft/Menu.rar
PostPosted: Mon Jan 31, 2005 12:56 pm    Post subject: Reply with quote
Page 13 of 24
