:: View topic - CX65 upgrade na fw25....neoriginalni kabel?
ross.p
PostPosted: Mon Feb 21, 2005 4:14 pm    Post subject: CX65 upgrade na fw25....neoriginalni kabel? Reply with quote
Mam CX65 a koupil jsem datovej kabel a dali mi nejakej od firmy Koracell(USB, dobijeni). Funguje v poho...ale chtel bych vedet jestli pres nej muzu nahrat FW25...dik
Orpheus
14900.34 SMM
PostPosted: Mon Feb 21, 2005 4:16 pm    Post subject: Reply with quote
A ako aky kabel sa hlasi? Skus a uvidis...
igi
PostPosted: Mon Feb 21, 2005 4:17 pm    Post subject: Re: CX65 upgrade na fw25....neoriginalni kabel? Reply with quote
najjednoduchsia cesta ako to zistit je vyskusat ho Very Happy
Mark Pawl
PostPosted: Mon Feb 21, 2005 4:47 pm    Post subject: Re: CX65 upgrade na fw25....neoriginalni kabel? Reply with quote
napiš *#06# sjeď uplně dolů a tam je pluged in: ... jestli se ti hlásí jako DCA - 510 tak půjde..
ross.p
PostPosted: Mon Feb 21, 2005 4:50 pm    Post subject: Re: CX65 upgrade na fw25....neoriginalni kabel? Reply with quote
Hlasi DCA-500... takze asi novej fw nebude co?
Orpheus
14900.34 SMM
PostPosted: Mon Feb 21, 2005 4:59 pm    Post subject: Reply with quote
bude..
ross.p
PostPosted: Mon Feb 21, 2005 6:14 pm    Post subject: Reply with quote
Upgrade se povedl...diky za rady
