:: View topic - How to update my el71 ????
Reply to topic     Forum Index -> Non Czech Languages Here
rioni76
PostPosted: Fri Feb 09, 2007 9:22 am    Post subject: How to update my el71 ???? Reply with quote
Hi to all of you , i dont speak CZ but i will ask in english, now i want to update the el71 i have an usb original cable DCA-140 and i download the firmware everything starts fine the phone is found ok on com 8 start to update aftes 10 sec the phone goes in off mode and everything fine but after 5-7 minutes keeps tell CANOT CONNECT PHONE. CHECK IF ATHACHED CORECTLY.???? please can some one help please , cheers
Erhalte Informationen:
Model: SIEMENS EL71 12 lg1
Telefon ist im "Normal Mode"
IMEI: 358941003257089
SecurityStatus: CustomerMode
HWID: 407
Akkuspannung: 3941 mV.
EELITE Info: free buffer 185280 bytes, free at all 206304 bytes, free for deleted 206304 bytes.
EEFULL Info: free buffer 62432 bytes, free at all 466432 bytes, free for deleted 204352 bytes.
Map Info: Date: 23/08/06, Variant: A 145, Std-Map/SW: 1/12, D-Map/Prov.: 100/56
Für erweiterte Informationen erst den SKEY senden!
Laufzeit: 2092566 Sekunden.
Gesprächszeit: 5951 Sekunden.
FlashID(1) - Hersteller: 0089 (Intel), Typ: 887E.
Anzahl Displays: 1
DisplayID 1 Typ: Unknown.
dnteam
PostPosted: Fri Feb 09, 2007 9:37 am    Post subject: Reply with quote
Update
Connect your mobile to the PC using one of the following cables compatible with your EL71:
Data Cable serial DCA-100 / Data Cable USB DCA-140 / Sync Station DSC-100
start the downloaded firmware file (.exe) and follow the instructions
have u try whit orginal firmeware
rioni76
PostPosted: Fri Feb 09, 2007 9:43 am    Post subject: Reply with quote
yes i have an original cable DCA-140 wich came with a phone and the firmware is official i tried 3 firmware same thing so i dont now what is the problem every thing starts fine updating but after 10-11 sec phone goes off mode and than after 5 minutes same can connect to phone ????
rioni76
PostPosted: Sat Feb 10, 2007 2:51 pm    Post subject: Reply with quote
Vladimir Curcic
PostPosted: Sun Feb 11, 2007 3:34 am    Post subject: Reply with quote
This old tip might help (?)
Quote:
Why firmware update with Data Cable USB DCA-510 will not work?
Solution
If any Bluetooth™ serial stuff is installed on your computer, update tool hangs during scanning BT-COM-Ports.
The mapped COM-port-number is greater than 10. Example: Update works fine if mapped to COM7.
Update does not work if mapped to COM24.
Hint: you cannot influence the mapped COM-portnumber, it is set by system during installing!
To solve problem:
Rightclick on workstation symbol on desktop -> properties -> Hardware -> Device Manager.
Click on the List at "Ports (COM & LPT)" and rightclick on BT-Port to deactivate it; also make a rightcklick to check -> properties -> settings -> advanced -> select a free COM-Port number less than 10.
S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
