Damir kolemjdoucí
Posted: Mon Jun 11, 2007 1:32 pm Post subject: T9 file |
Hello,
I've installed the latest firmware (FW52) for my Siemens SL75. The problem is that is doesn't have any T9 file. Is it possible to install the dutch T9 on my mobile?
Damir |
drp ostřílený diskusník
 Joined: 21 Dec 2006 Posts: 559 Location: Čejkovice Phone: m65,se w610 31463.96 SMM
Posted: Mon Jun 11, 2007 2:11 pm Post subject: |
yes(raknu vam ze moc anglicky neumim takze sem si to prelozil slovnikem a jestly to prelozilo spravne tak yas)  _________________
Damir kolemjdoucí
Posted: Mon Jun 11, 2007 4:41 pm Post subject: |
Where can i find a dutch T9 file? And can someone help me to install it? |
dohaa32 kolemjdoucí
Posted: Wed Jun 13, 2007 1:52 pm Post subject: |
Damir wrote: | Where can i find a dutch T9 file? And can someone help me to install it? |
As far as i know it is difficult in SL75, and s68
i have s68 , made a backup from another s68 with same version and put it on the other s68, but the t9 won´t work...
i think it is not like the x65 |
Vladimir Curcic badatel
Posted: Thu Jun 14, 2007 1:27 am Post subject: |
9 dohaa32 wrote: | Damir wrote: | Where can i find a dutch T9 file? And can someone help me to install it? |
Someone, somewhere, on some German forum wrote this for S75:
Set your menu language / T9 to English
Restart the phone.
Connect the phone to the PC and copy your T9 dictionaries to the phone's folder: \Data\System\T9\
Restart the phone
Activate new T9 dictionary
Restart the phone
Set your menu language / T9 language
See if it works (!?!) _________________ S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75 |
dohaa32 kolemjdoucí
Posted: Thu Jun 14, 2007 11:24 am Post subject: |
Vladimir Curcic wrote: | 9 dohaa32 wrote: | Damir wrote: | Where can i find a dutch T9 file? And can someone help me to install it? |
Restart the phone.
Restart the phone
Restart the phone
See if it works (!?!) |
thnx for reply
did all that, but when choosing t9 am getting error, file not readble, if i remove same t9 from the working phone (with t9) and put again it works, but will not work on other phones:(
do u know how to export/import (t9) work? |
flemo ostřílený diskusník
3205.06 SMM
Posted: Thu Jun 14, 2007 11:50 am Post subject: |
Problem is, that you need to installed something like license for each t9 dictionary you want to use.
If you remove some ldb file, you can put it back any time and it will work, because license file remains in phone, but if you add ldb file, that was never before installed into phone, it will be unreadable.
It is discussed also here, you can find there package of t9 files and their license files:
http://www.siemensmania.cz/forum/viewtopic.php?p=340969
License files are installed through "Config" drive. Unfortunatelly, you need to have phone in "Factory mode" security status to be able to see and write on "Config" drive. You need SKEY. _________________ ....S65-AX75-CX75-EL71-E71-SXG75-E71-S68-C81-M81 |
dohaa32 kolemjdoucí
Posted: Thu Jun 14, 2007 12:52 pm Post subject: |
flemo wrote: | Problem is, that you need to installed something like license for each t9 dictionary you want to use.
License files are installed through "Config" drive. Unfortunatelly, you need to have phone in "Factory mode" security status to be able to see and write on "Config" drive. You need SKEY. |
thnx again for ur effort
can i read license file from a phone and put it 2 another one?
do u have licene file for danish?
what program i have 2 use so i can c `Config` drive?
Thnx Again |
3205.06 SMM
Posted: Thu Jun 14, 2007 1:01 pm Post subject: |
License files cannot be copied from one phone to another. If you look into the file (T9.zip, that I have given link in other topic), there are files with extenion drc. These files are used by phone to create license files, when copied into Config/drm/pre_inst. I haven't any other languages, only these you can find in zip.
If you can read german, here is some info how to get phone into Factory mode.
http://forum.modopo.com/showpost.php?p=118668&postcount=1 _________________ ....S65-AX75-CX75-EL71-E71-SXG75-E71-S68-C81-M81 |
dohaa32 kolemjdoucí
Posted: Thu Jun 14, 2007 1:16 pm Post subject: |
flemo wrote: | License files cannot be copied from one phone to another. If you look into the file (T9.zip, that I have given link in other topic), there are files with extenion drc. These files are used by phone to create license files, when copied into Config/drm/pre_inst. I haven't any other languages, only these you can find in zip.
http://forum.modopo.com/showpost.php?p=118668&postcount=1 |
yes understand now thnx..
by the way i think i can go around this problem if i flash.xfs file (it has the language and t9 i need), the problem is that':
I am trying to update .xfs to my sl75, but getting this error:
Function not supported until now in Mobile.
am using winsup 4.18
Model: SIEMENS SL75 39 lg2
xfs file: SL75_2_no-Retail-NORDIC_39_0358.xfs
can u please help |
3205.06 SMM
Posted: Thu Jun 14, 2007 1:20 pm Post subject: |
Sorry, I have no experience with xfs files. Maybe you need "Factory mode" also for this operation _________________ ....S65-AX75-CX75-EL71-E71-SXG75-E71-S68-C81-M81 |
dohaa32 kolemjdoucí
Posted: Mon Jun 18, 2007 11:13 am Post subject: |
flemo wrote: | Sorry, I have no experience with xfs files. Maybe you need "Factory mode" also for this operation |
THNX FOR UR HELP, BUT NEED MORE (AM GREEDY FOR INFO)
i used martech for reeding the full flash from s68..generate the keys esn boot and skey..
i need t know which program 2 use t acces the Config/drm/pre_inst., because still not working for the other s68, even after writing full flash and changing the imei to original again... sorry i can´t german. |
dohaa32 kolemjdoucí
Posted: Thu Jun 21, 2007 3:19 pm Post subject: |
I could manage everything now , but the only think i need is the t9da.drc file...
i could download one ffsinit file with t9da.drc inside, but the problem is that I can unpack/extract the files from this file...tried many exe unpackers but no luck...Any Idea...?
appreciate ur help. |
Posted: Fri Jun 22, 2007 1:18 am Post subject: |
dohaa32 wrote: | flemo wrote: | Sorry, I have no experience with xfs files. Maybe you need "Factory mode" also for this operation |
Example, you have the FFSInit file "FFSInit_SL75_2_ua-retail_39_0358.exe"
1. Copy your FFSInit file to C:\TEMP
2. Start any Winswup firmware update file and leave it running
3. Start / Run:
C:\Temp\FFSInit_SL75_2_ua-retail_39_0358.exe /UNZIP
(there is a blank space before "/UNZIP"!)
And you will find a new folder: C:\Temp\FFSTool with all the contents of your FFSInit file unpacked.
dohaa32 kolemjdoucí
Posted: Fri Jun 22, 2007 9:57 am Post subject: |
Vladimir Curcic wrote: | dohaa32 wrote: | flemo wrote: | Sorry, I have no experience with xfs files. Maybe you need "Factory mode" also for this operation |
3. Start / Run:
thanks for reply and info
i did all that but no unpacked files at the temp folder( i created and put the ffsinit file).
just the init file pops up when running the command:
c:\ffsinit.exe\ UNZIP
P.S I just ran any winsup without connecting any phone 2 it.
any idea what am doing wrong?
shall i have UNZIP program in same temp folder or what? |
