:: View topic - KABEl FW
KABEl FW
Goto page 1, 2  Next
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x65, x70
Stifler3
PostPosted: Mon Jan 10, 2005 8:16 pm    Post subject: KABEl FW Reply with quote
Mam dotaz kamos ma CX65 a ma k nemu kabel ..Slo by pres ten jeho kabel mi prehrat FW..přecejenom nabiječka mi funguje i z C62 ..Jo a jste se si jisti ze tim nestratim zaruku
Orpheus
14900.34 SMM
PostPosted: Mon Jan 10, 2005 8:55 pm    Post subject: Reply with quote
A jaky typ to je?!
Guest
PostPosted: Wed Jan 12, 2005 9:03 pm    Post subject: Reply with quote
no a jaky mas ty typ telefonu???jinak prehranim FW bys zaruku ztratit nemel!!!
No11
PostPosted: Wed Jan 12, 2005 10:52 pm    Post subject: Reply with quote
a jaký typ kabelu.. Modli se aby ne DCA540.. Shame on you
mot m3888=>mot t2288R => N3310=>N3330=>N3410=>N6310i =>CT65 fw12, FW25,Clear T-mobile, FW33,=>M65 FW12,FW25 patched,FW33 patched, FW41 patched, FW 43 PAtched
Womanizer
PostPosted: Thu Jan 13, 2005 4:16 am    Post subject: Re: KABEl FW Reply with quote
Zkus si nainstalovat ovladace k tomu kabelu a pripoj telefon.Potom namackej na mobilu *#06# ....pak zmackni Vice a najed si uplne dolu.Je tam polozka Acc.: Pokud tam budes mit plugged in:DCA 510,tak mas vyhrano a kabel je servisni.Myslim,ze origo FW by mel jit i s DCA 500.Pokud tam mas DCA 540,tak ti to nepujde..
N7110=>N3310=>SonyCMDJ7=>SIEMENS M65
No11
PostPosted: Thu Jan 13, 2005 4:47 am    Post subject: Reply with quote
ano mam orig DCA 500 a FW jde taktéž
Dieg0
19990.28 SMM
PostPosted: Thu Jan 13, 2005 6:42 am    Post subject: Reply with quote
Prosim ako prosim prosim ako nahram FW cez DCA500 do mojej C65ky pls pls pls pls Chcel by som FW33 aby som moholo 3gp-cka prehravat pls pls diki vopred za odpoved.Dieg0
Dieg0
19990.28 SMM
PostPosted: Thu Jan 13, 2005 1:44 pm    Post subject: Reply with quote
PROSIM PORADTE PLS AKO MAM PREHRAT FW NA 33 PROSIM PORADTE AJ DOSTUPNE PROGRAMY A TAK MAM ORIGINAL DCA 500.Dieg0
PostPosted: Thu Jan 13, 2005 1:52 pm    Post subject: Reply with quote
Se zapnutým telefonem spustíš update. Musíš mít nabitou baterii na plno.
Dieg0
19990.28 SMM
PostPosted: Thu Jan 13, 2005 2:05 pm    Post subject: Reply with quote
A prosim te brouzdal jsem na SM a nikde jsem to nenasle nemoh by si mi to popsat prosim moc me to laka mat tu 33 FW.Potom se chci zeptat stracim tim zaruku?A jeste ze jakej program pouzit a jak si udelat zalohu.Dieg0
BEZY
81.16 SMM
PostPosted: Thu Jan 13, 2005 2:08 pm    Post subject: Reply with quote
Jak jakej program? Normálně stáhni ten FW-je to exe soubor, ten spustíš a nahraje ti do tlf. novej FW. Zálohu uděláš přes V-klay, jenže je se servisnim kabelem.
http://www.bezysoftware.net
Brew Mobile Commander 2.0
Dieg0
19990.28 SMM
PostPosted: Thu Jan 13, 2005 2:09 pm    Post subject: Reply with quote
A kdyz prehraju FW nestracim zaruku?
BEZY
81.16 SMM
PostPosted: Thu Jan 13, 2005 2:11 pm    Post subject: Reply with quote
Pokud je ofiko tak ne
PostPosted: Thu Jan 13, 2005 2:13 pm    Post subject: Reply with quote
Bez servisního kabelu si kompletní zálohu neuděláš. A asi jsi špatně hledal nebo vůbec. SM není jenom fórum http://www.siemensmania.cz/firmware.php
Dieg0
19990.28 SMM
Co je to ofiko?A kolik se nahrava?A kdyz chci naspet tak muzu znova s DCA500 na FW25?.Dieg0
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x65, x70 All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
