:: View topic - Need schematic cable for flash X65
Nueng
PostPosted: Thu Feb 17, 2005 9:06 am    Post subject: Need schematic cable for flash X65 Reply with quote
Need schematic cable for flash X65,SX1,SL55,.......New siemens Phone
SURE AND EASY!!!!!!!!!!!!!!
Please help me
Thank for your help
wizaard
PostPosted: Thu Feb 17, 2005 9:13 am    Post subject: Re: Need schematic cable for flash X65 Reply with quote
Please help me
Thank for your help
Hi there, just enter the following link with username: hanni76 and password: hanni. That's all.
http://www.mobile-files.ru/forum/attachment.php?s=&postid=166938
Dieg0
19990.28 SMM
PostPosted: Thu Feb 17, 2005 9:14 am    Post subject: Reply with quote
I don´t have cable DCA510.I have only cable from CPA type: MA-8720-C.Sad.Dieg0
Nueng
PostPosted: Fri Feb 18, 2005 10:30 am    Post subject: Reply with quote
Thank a lot
Thankzzzzzzzzzzzzzzzzzzz
Nueng
PostPosted: Fri Feb 18, 2005 12:26 pm    Post subject: Reply with quote
the picture that you give me
It can use with SST,X65Flasher,winswup and XXX.Xbz?
I want want to use it with there
Flasher and upgrade firmware
should I install driver ? where download driver?
jdobry
PostPosted: Fri Feb 18, 2005 1:19 pm    Post subject: cable schematics Reply with quote
Add http://www.mobile-files.ru/forum/attachment.php?s=&postid=166938
This cable is eqivalent to DCA-540 cable with same limitation. This mean, that you can use only MCM software and oficial SW update.
Not exist way, how to use SST,X65Flasher,winswup, EEPROM tool and etc.
You must use DCA-510 cable for it, or MA-8730-C, or MA-8720-C with modification (disconnect pin 1 on connector, use switch)
