:: View topic - C/M35 flash v18 by Poochini
Reply to topic     Forum Index -> x62 a starší řady -> x35, x25 a starší
Poochini
10.42 SMM
PostPosted: Fri Jun 03, 2005 6:03 pm    Post subject: C/M35 flash v18 by Poochini Reply with quote
Hello
Short info:
* Changes animations in menu (menu, alarm, ringing)
* no 'PIK' when you calling
* nokia idnicators
* no problem with "%english"
* sound in call is now at 50 second
* on/off ligth on '*' key
* net-monitor
* no more baterry empty sound
* counter in SMS
* termomert
* data in Nd 01.08
* hide softkeys
* data is on the down of screen
* now, its possible to load bigger logo
* icon of new SMS, missed call, profile, vibra is on the top of screen
* screen saver, when you lock keyboard
* calendar for all year
--FLASH--
best regards!
http://x35zone.prv.pl - best site about c/m/s35
PostPosted: Fri Jun 03, 2005 6:15 pm    Post subject: Reply with quote
Thank for your fullflash wink
sssugi
667.50 SMM
PostPosted: Fri Jun 03, 2005 9:19 pm    Post subject: Reply with quote
To je tuning FF?V angličtine sa moc nevyznám
Ak áno tak je to na c35 super Applause
Siemens M65+S65+C55+DCA 510
ICQ Number
Xmax88
1271.42 SMM
PostPosted: Fri Jun 03, 2005 9:35 pm    Post subject: . Reply with quote
Fustej Tuning na tenhle starej dobrej telefon jen skoda ze uz ho nemam
SIE C35i - FW M35i --> SE T100 -->SIE M55 - FW91+patche -->
Siemens SX1- na ND [momentalne funkcni]
ICQ Number
PostPosted: Fri Jun 03, 2005 10:06 pm    Post subject: Reply with quote
Aj stare telefony rady x35,x45,x50 s monochrom displejom sa daju dobre vytunit....az som sa niekedy cudoval,ked som pridaval na stranku patche pre tieto telefony....
...inac ten,co sem dal ten FF je Poliak,takze ten FF by mal obsahovat CZ/SK
Haldy
698.10 SMM
PostPosted: Tue Aug 09, 2005 1:40 pm    Post subject: FF by Poochini Reply with quote
Tak jsem ten FF zkousel a je docela v pohode, ale:
- ten FF se musi nahrat pres x35 Flasher pomoci tlacitka Repair Phone a pak odblokovat treba pres Freiu s vlastnim IMEI (zkousel jsem ten FF nahrat pres VKlay, ale nepodarilo se mi telefon rozbehnout - nevim, kde byl problem Sad )
- je tam polska T9 a pri pokusu prehrat tam ceskou pres WS, tak uz telefon nezapnu Sad
- dny v tydnu jsou tam polsky, ale to uz jsem predelal do cestiny po uprave patche Smile
- telefon se mi vypne kdyz v menu zvolim polozku schuzky (kdyz zvolim to same pod polozkou budik, tak je vse OK) tomu moc nerozumim, ale mozna to ma na svedomi, nejaky jiny patch, ktery jsem tam nahral pozdeji
....a jeste jedna vecicka s tim kalendarem - moc jsem nepochopil jeho funkci Sad
P.S.: Chystam se vytvorit vlastni "vypatchovany" FF s ceskou T9, ceskymi znaky a zmenou nazvu nekterych polozek v menu (napr. schuzky a budik), ktery pak zverejnim, nebo poslu Hannimu na zverejneni Smile .
Mobilní historie:
Dancall => C35i@M35i => ME45@S45i => A55,A57@C55 => C65 => M75 (všechny Patchované) => E-Ten Glofish X500 (WM6 lite)
ICQ Number
PostPosted: Tue Aug 09, 2005 4:21 pm    Post subject: Reply with quote
Kludne posli... wink
sonix
314.02 SMM
PostPosted: Tue Mar 14, 2006 6:45 pm    Post subject: Reply with quote
Nemůžu nikde najít ten "vypatchovany" FF s českou T9 a českými znaky, co vytvořil HALDY. Dost bych to chtěl. Poradí mi někdo? Haldy mi neodpovídá. Sad
AC55
V360 - motorola
ICQ Number
sowwa
PostPosted: Sat May 27, 2006 3:53 pm    Post subject: Re: C/M35 flash v18 by Poochini Reply with quote
Má prosím niekto tu FF už v telefone?ak áno mohol by mi ju prosím vytiahnuť cez V-klay a poslať d.sowwa@gmail.com . Ide o to že FF čo je tu na stiahnutie sa da nahrať iba cez x35flasher a ten žial pod XP nechodí.Preto by som vás chcel pekne poprosiť.Ďakujem
ICQ Number
sonix
314.02 SMM
PostPosted: Mon Jun 05, 2006 7:32 am    Post subject: tuningová FF C35i Reply with quote
Jestli to ještě chceš, tak ti to klidně můžu poslat (je to od haldyho), ale byl jsem z toho nějak zklamanej, dost mě vadilo, že tam nefunguje budík ani upomínky. Takže nedávno jsem sehnal ještě další FF, tak ti to můžu taky poslat (a našel jsem ještě nějaký patche, co nejsou tady na SM).
AC55
V360 - motorola
ICQ Number
sowwa
PostPosted: Mon Jun 05, 2006 9:04 pm    Post subject: Reply with quote
Ďakujem pekne už sa mi podarilo dostať ten flash do telefonu ide to celkom jednoducho akýmkolvek programom na flashovanie(ja som použil V-klay,Unisiemens) len treba po flashovani použiť patch na zmenu flash ID. Flash ID telefonu musí byť rovnake ako flash id softwaru čo nahrame. Tiež som bol sklamaný s Poochiniho softu tak som nahral soft by Jabol je o dosť lepší no stlae mi tam vadí pár detailov. Teda budem veľmi rád ak mi pošleš tie patche aj flashu tak isto ti môžem ja poslať ak by si chcel ďakujem Laco
ICQ Number
132978.34 SMM
PostPosted: Thu May 17, 2012 6:06 pm    Post subject: Reply with quote
Po 7 letech asi hondně blbá otázka, ale nemáte někdo náhodou tuhle flash? Mr. Green
Konečně jsem si sehnal kabel na x35, tak bych chtěl vytunit C35 co tu mám ve vytrínce a tohle vypadá úžasně.. Mr.Blue
Poochini
10.42 SMM
PostPosted: Sat May 19, 2012 8:29 am    Post subject: Reply with quote
Hello
I still got this phone with this flash and it`s still working Smile
132978.34 SMM
PostPosted: Sun May 20, 2012 8:45 am    Post subject: Reply with quote
Hi, can you upload this flash for me? Smile
The download link is not working.. Sad
Reply to topic     Forum Index -> x62 a starší řady -> x35, x25 a starší All times are GMT + 1 Hour
