:: View topic - dca-510/com very big problem
Reply to topic     Forum Index -> Non Czech Languages Here
pbw2
PostPosted: Sat Oct 22, 2005 12:40 pm    Post subject: dca-510/com very big problem Reply with quote
Ok,first let me introduce myself .i'm johny.i write here because it is said to be the best siemens site in the world(i will agree if you help me )
Secondly i want to apologise for writing not in cesky ,the reason is simple i don't know this language .
My problem is following,recently i bought data cable for siemens dca-510,it is ended with com.I hoped that using this cable i would flash and patch my phone and laso take off simlock.in my phone siemens cx70 ,sw version 36,everything seems to be all rightb ,ubder acc i have plugged in:dca-510.however my computer doesn't see the cable.I think i have tried everything which was advised,i used simoco ,direct softkey editor or mpm,but there is no effect.How to solve tghis problem?i have also tried changing the speed and irq's of the com port in contriol panel but it doesn't work.Plizzzzz help.
Little_S
PostPosted: Sat Oct 22, 2005 4:11 pm    Post subject: Re: dca-510/com very big problem Reply with quote
pbw2 wrote:
My problem is following,recently i bought data cable for siemens dca-510,it is ended with com...
first of all. the DCA-510 can't be "ended" with COM, because DCA-510 is a USB cable (for that you need a COM emulating driver)
original Siemens COM cable is only DCA-500 but with it you won't be able to do any service operation
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
pbw2
PostPosted: Sat Oct 22, 2005 5:10 pm    Post subject: Reply with quote
i am not an expert ,but under acc category i have dca-510,and it is ended with com,i have one big plea ,could you translate my post into cesky language and ask about it on the main forum?tHx in advance
Little_S
PostPosted: Sat Oct 22, 2005 7:27 pm    Post subject: Reply with quote
there's no need for that. many of our users speak english
try connecting mobile to SiMoCo with COM port 1 and/or 2 setting (i think you don't have more than 2 COM ports in your computer)
for windows COM ports setting you can try the highest speed, no more.
and about that DCA-510 thing - where is that cable from? there were few COM port cables that didn't have MAX323 chip(instead a pile of transistors,diodes,...)....i think they were not working correctly for all x55s (and naturally for x65s,x75s)
pbw2
PostPosted: Sun Oct 23, 2005 8:20 am    Post subject: Reply with quote
ok,thx for help,i bought it on ebay,seller told me that maybe the cable is broken,so he will send me another.Hope to see you soon
kicco_79
PostPosted: Thu Jan 19, 2006 12:33 pm    Post subject: Reply with quote
Hello, I've a Siemens original DCA-510 usb cable. My problem is that:
I've an M75 and when the phone is connected to pc using DCA-510 it's all ok.. when i receive an sms or an incoming call, the phone seems to be disconnected and i must disconnect the cable and replug it (onto my usb port on pc side) and then it work. another problem is with modem driver (GPRS VIA COM) that don't work.. Any Idea?
PostPosted: Thu Jan 19, 2006 5:40 pm    Post subject: Reply with quote
Problem with plugging could be because of not original cable. Sometimes I must do it too.
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
