:: View topic - Mam maly problem s vycistenim fonu
jaroslavg
PostPosted: Tue Oct 25, 2005 5:26 pm    Post subject: Mam maly problem s vycistenim fonu Reply with quote
Chcel by som vediet ako mam precistit fon ......trocha blbne po niektorych patchoch....nejak sa mi podarilo vymazat zalohu z kompu a teraz ho chcem mat na 100%
ide hlavne o to ze niektore patche uz nechce nahrat a ked nejake idu tak zistim ze napr. sa fon nechce zapnut alebo sa nechce nabijat...
diki. Brick wall
siemens for all people
cool>cx65<cool
pecanz
14931.66 SMM
PostPosted: Tue Oct 25, 2005 5:28 pm    Post subject: Re: Mam maly problem s vycistenim fonu Reply with quote
diki. Brick wall
Tak přehraj FW a všecky patche ti zmiznou... wink
jaroslavg
PostPosted: Tue Oct 25, 2005 5:31 pm    Post subject: Re: Mam maly problem s vycistenim fonu Reply with quote
diki. Brick wall
myslis ze som to neskusal....fw som nahral ale i tak haluzi a ten patch na odstranenie starych dat nejde aplikovat
cool>cx65<cool
jaroslavg
PostPosted: Tue Oct 25, 2005 5:34 pm    Post subject: Re: Mam maly problem s vycistenim fonu Reply with quote
diki. Brick wall
myslis zeby som mohol urobit zalohu bootcore a eeprom ,nahral by som ff zo SM a potom by som tam nahral tu zalohu?
cool>cx65<cool
Palio
veterán
veterán
PostPosted: Tue Oct 25, 2005 10:33 pm    Post subject: Reply with quote
jj. a bootcore potom prehravat nemusis (nesmies totizto povolit zapis do bc pri prehravani ff, lebo by si nemal loadery).
SGS2
PostPosted: Tue Oct 25, 2005 10:40 pm    Post subject: Re: Mam maly problem s vycistenim fonu Reply with quote
@jaroslavg:
Pouzi tento patch na odstranenie starych dat z firmware.
Vytvor REPAIR patch. Tj aplikuj napriek varovaniu.
BTW tu je diskusia k patchu.
Arrow http://siemensmania.cz/forum/viewtopic.php?t=13695&postdays=0&postorder=asc&start=0
jaroslavg
PostPosted: Wed Oct 26, 2005 5:49 pm    Post subject: Re: Mam maly problem s vycistenim fonu Reply with quote
Lb01 wrote:
@jaroslavg:
az na to ze ten patch nejde aplikovat Think
cool>cx65<cool
jaroslavg
PostPosted: Wed Oct 26, 2005 5:51 pm    Post subject: Reply with quote
a cez co bude lepsie tam nahrat ten FF.
cool>cx65<cool
jamaica
17095.68 SMM
PostPosted: Wed Oct 26, 2005 6:31 pm    Post subject: Reply with quote
žádnej FW nepřehrávej,udělej si očistu buferu eeprom a bude to ok wink
Arrow http://www.siemensmania.cz/content.php?id=374
Bůh odpouští, JÁ NE!
LG G2 d802
jaroslavg
PostPosted: Tue Nov 01, 2005 12:58 pm    Post subject: Reply with quote
Tu ocistu mozem urobit aj na fon s patchmi alebo musi byt cisty?
cool>cx65<cool
Dieg0
19990.28 SMM
PostPosted: Tue Nov 01, 2005 1:09 pm    Post subject: Reply with quote
Ocista sa robi na zadrbane veci nie na ciste Smile)
PostPosted: Tue Nov 01, 2005 1:10 pm    Post subject: Reply with quote
Očistu EEPROM můžeš dělat i s patchovaným telefonem, ale to ti na očistu telefonu nestačí, je to jenom část. Na absolutní očistu musíš ještě přehrát FW, a ne že ne, a nahrtá FFSinit pro očistu "disků" (toto se zanedbává a bývá to příčinou mnoha problémů).
